Audio comes through h/phones AND speakers
  1. Posts : 259
    Windows 7 Panasonic CF F9 (used to have CF F8)
    Any idea why when I plug my headphones into my machine the sound still comes out of the speakers?
    This PC is a custom built in the sense that I ordered the parts and installed the OS myself - which is 64 bit W7.
    Thanks!!!!!!!
  2. Posts : 2,528
    Windows 7 x64 Ultimate
    That's generally pretty normal. A PC isn't a pocket radio Mine has always been like that.
    That said, a lot depends on your sound drivers. Some drivers may auto mute the speakers while others don't... Or there may be a setting in the driver's control panel that allows you to turn that on or off.
  3. Posts : 7,730
    Windows 7 Ultimate SP1 64-Bit
    Thanks!!!!!!!
    Chances are you're using both the onboard sound and a dedicated sound card.
    You need to check your BIOS to see what is enabled.
    Certainly, on my computer the speakers are muted when I plug my headphones into the front connection - I just use the onboard sound as I don't have a separate sound card.
  4. Posts : 259
    [QUOTE=seavixen32;1521779]
    Thanks - I checked the BIOS but didnt see any settings for audio. Pls note that this machine was shipped w/out any OS so I had to use a retail disk I had. Thanks -
    I am guessing it is a driver issue....or rather lack of one...
  5. Posts : 7,730
  6. Posts : 259
    thanks appreciate all the help
