Sound Distortion With SATA CD/DVD Player
  1. Posts : 170
    Desktop Win 10 Pro 64 bit, Laptop Win 7 Home 64 bit
    I have an ATA and also a new SATA CD/DVD Rom drives. The older ATA device plays CD music fine. However the new SATA device causes terrible distortion as if there is a loose nail buzzing in the speakers. I know it must be something to do with incompatible hardware settings but I have no idea where to start. Your advice would be appreciated.
    Kind Regards
    Chris
    PS. I did find some links relating to sound distortion but don't know how relevant they are to this issue:
    http://winhlp.com/node/10
    http://www.pcmech.com/article/how-to...-pc-is-active/
  2. Posts : 9,582
    Windows 8.1 Pro RTM x64
    Have you tried attaching the analog audio cable to see if you get better results that way?
  3. Posts : 170
    Thanks for your reply Dwarf. In theory this could solve the problem but there are problems. The older IDE ATA DVD rom which plays fine has an audio out plug but unfortunately the new SATA DVD rom with the distortion problem does not. Also the on board sound hardware does not appear to have an audio input plug. I suspect there must be a hardware setting somewhere that will help.
    Kind Regards
    Chris
  4. Posts : 170
    Update:
    After doing more testing it seems the distortion only occurs with original Time Life CD's. Other CD's seem to play OK. I am not sure why this is hapening. Maybe the CD's are stamped instead of burned or the recording volume may be higher than the drive can handle. There might also be some copy protection code that is interfering with the normal playback with this drive. The other drive can play them fine.
    I hope I can find a work around.
    Kind Regards
    Chris
  5. Posts : 170
    Solved
    I am glad to say I found a solution to the problem. I downloaded, installed and ran Samsung live firmware update. After the reboot the problematic DVD/CD Rom drives plays all CD's (including Time Life CD's) crystal clear.
    Samsung Firmware Live Update (click on icon Download Full)
    ODD Support
    Kind Regards
    Chris
