Mic volume very low even when maxed
  1. Posts : 41
    Windows 7 x64 Ultimate
    Hi everyone,
    I've noticed with Windows 7, the mic volume seems to be very low. I've cranked it up to max volume already. If I use mic boost, the sound quality becomes ****.
    Currently using Realtek HD Audio Manager and Steelseries 5H headset. (If it matters, I'm using the lines, no usb)
  2. Posts : 1,011
    Windows 7 Ultimate x64 (Retail)
    Hi, don't know if this will apply to your situation but I was having what I thought were mic problems and ultimately figured out that my mic doesn't appear to work well for VOIP apps when I'm using utorrent to do what utorrent does. If I pause utorrent, the mic starts working normally again.
  3. Posts : 41
    hmm you do have a weird solution, but unfortunately I've been having this prolem even with utorrent off.
  4. Posts : 11
    windows 7 pro
    I am also having the same problem with the built in mike on my cam, it worked fine on XP but not on 7. Have managed to get another wired mike to work, but would like to find a solution.
  5. Posts : 11,840
    64-bit Windows 8.1 Pro
    Are you using the latest drivers for your webcam???
  6. Posts : 11
    windows 7 pro
    Yes, updated them when I built this computer a few days ago.
  7. Posts : 8,870
    Try doing this and check the two variables on the right. Use the DVD quality settings also like in the second picture.
    Attached Thumbnails Attached Thumbnails Mic volume very low even when maxed-mic-application-control-device.png   Mic volume very low even when maxed-application-control-device.png
  8. Posts : 11
    windows 7 pro
    Thanks very much, thoses settings have done the job. Your help was greatly apprisiated, rep added
  9. Posts : 8,870
    Glad you got it working Psionguy. Sometimes the simple solutions work the best.
  10. Posts : 41
    doesn't work for me
    Tried it, mic volume still absurdly low. Have to yell at 100 mic volume to even be heard.
