Windows 7: Sound Problem
12 Aug 2011   #1
kjeimster
Windows 7 home premium
Sound Problem
I am currently playing a game threw a hdmi cable so it displays on my hdtv and i have headphones with a mic so i can talk and the sound plays through my tv but not my headphones is there a way to make it play threw both?
12 Aug 2011   #2
stormy13
Microsoft MVP
Win 7 Ultimate x64
kjeimster, welcome to the Seven Forums.
In all likelihood what you're looking to do isn't possible as Windows 7 only allows for one default audio playback device at a time. Also the HDMI audio is likely integrated into whatever video card your computer has and is totally separate from the onboard audio which your headset and mic are connected to.
You should be able to use the mic as the default recording device regardless of which is the default playback, but if you want to use the headphones then you will have to set the onboard audio as the default playback device.
12 Aug 2011   #3
paulpicks21
Windows 7 Professional 64 bit
I like to hear the game sounds just through my speakers and just voice chat through my headset.
I use the onboard sound of my motherboard for the speakers and I bought a dirt cheap 10 pci soundcard to plug my headset into, that way I can separate the sounds exactly as I want to.
The same would work for you, you could use the hdmi from the graphics for sound to the tv then add a cheap soundcard for your headset, that's assuming you just want to use the headset to chat.
If you use programs such as xfire/skype etc then you can set the input/output devices accordingly.
Cheers
Paul.
12 Aug 2011   #4
stormy13
Microsoft MVP
Win 7 Ultimate x64
Quote   Quote: Originally Posted by paulpicks21 View Post
Paul that is the only way to make that sort of thing to work; two audio devices and two programs with at least one of the programs having the option to use something other than the default playback device.
kjeimster will have to confirm but I get the impression that he is looking to have the same thing play on the TV and headset at the same time.
12 Aug 2011   #5
paulpicks21
Yeah stormy, after posting a while ago I quickly edited my post to add "assuming you just want to use the headset to chat"
Audio can be a tricky thing at times, agreed he needs to confirm exactly what he wants from it.
 Sound Problem
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound problem perrsists even after new sound card
As some of you might remember, a few weeks ago I had a problem with sound after I built a new PC and kept my old Win 7 installation using sysprep: http://www.sevenforums.com/sound-audio/280175-onboard-sound-issue-new-pc-build-2.html#post2308990. The problem was that the volume levels were off, and...
Sound problem
Hi all, I had this problem with my laptop sound randomly disappears and it comes back after a while like 15 min or so.I have Realtek HD Audio Driver installed.Is it problem with my driver? Can anyone help me with this? i am despreate !!!
Sound problem - need to 'scan for hardware changes' to get sound
Hi everybody I have a fairly strange problem with my Laptop. It came originally with Vista and a while ago I updated to Windows 7 32bit Home Premium. Since then I don't have any sound after booting the Laptop. By chance I found out that when I go into the device manager, right click on the sound...
Hardware & Devices
Windows Media Player Problem - Sound/skipping problem.
Oh look, another windows media player problem, lol. Well, it's something really weird, at first i thought it was just my computer being all slow or the file was messed up, No matter what movie or format i play it makes this weird screeching noise. It also lags pretty bad. I tried the scans, i did...
Music, Pictures & Video
sound problem
Hello, I have a sound problem on my HP Pavillon desktop (windows 7). Everytime, after some hours of use, I hear sound clicks&pops. I restart, and the problem is back after some hours. When sound clicks&pops occurs, I see abnormal CPU usage in task manager. Like going back and forth...
