Windows 7: sound problems with Realtek ALC 882 sound card
28 Apr 2009   #11
abaddon3k
Win7 7000 x64
sure thing. the help would be great seeing as i have exhausted all my options.
Its is Realtek ALC888 7.1 HD integrated into an ABIT I-N73HD
28 Apr 2009   #12
t2n
Windows 7 x64
you could try these from dell:
http://ftp.us.dell.com/audio/Realtek...01_R176166.exe
same model, this way worked for me once. good luck!
28 Apr 2009   #13
abaddon3k
Win7 7000 x64
i'll give them a try, thanks a lot!
01 May 2009   #14
HKeleher
Windows 7 Ultimate x64 RC1 (7100), Vista Ultimate x64 SP1
I'm using the 2.22 drivers (Vista x64 version) directly downloaded from Realtek's site. Works like a champ. I've read that you should download the .zip version. Just in case you downloaded the .exe version that could be worth a distant try.
11 May 2009   #15
LiesmithLoki
Windows 7 32-bit
I have the same computer system as the OP. I've installed the latest Realtek Device drivers for Vista 32/64 bit from the website, and the driver installs fine, and the computer recognizes it, however sound refuses to play from the speakers. When I wear my headphones I can faintly hear the sound, but nowhere near a satisfactory level, and that's at 100% volume on all counts. My sound card is Realtek ALC 882.
I tried it with 64 bit Windows 7, and since that didn't work, I tried 32-bit to see if it would make and difference, which it didn't, so currently, I'm using 32-bit Windows 7.
Any help would be greatly appreciated.
15 May 2009   #16
aper3
windows 7
I have Realtek 880 High Definition Audio on a Asus MotherBoard. My problems look like projectd24 . Do you have an ATI HD graphic card with integrated HDMI , because my windows used the HDMI sound as default and didn't reconized the REALTEK . Afther several hour of search I went into my Bios in the advanced option and I put my integrated audio to ENABLE instead of AUTO and windows automaticly install my REALTEK audio driver and sound work great! :P
18 Aug 2009   #17
ruggb
windows 7
OK, I think my problem is the same. It is NOT solved BUT............
If I plug the headphone into the MIKE input I get a popup that asks what device I plugged in. If I select HEADPHONE, everything works like it did in XP -- except that the headphone is plugged into the mike port.
is yours the same?????????
definitely and issue.
04 Dec 2009   #18
apmcomp
Windows 7, Linux, MAC OS X , Windows XP
thanks to aper3 for the recommendation. I was working on an HP media center edition. By changing the audio from auto to enabled, Windows 7 picked up the hardware and installed the appropriate software for the machine. Many thanks.
Regards,
Paul
Paul M. Muhlbach, A+, CNA, MCSE, MCT
Calgary, AB
05 Dec 2009   #19
ruggb
windows 7
a follow up on my issue with the headphone jack not working.
I decided it HAD to be a h/w issue so I pulled everything apart determined to find it this time. (I looked once before but didn't find anything).
AH HA!!!!!
The headphone jack switch was not working. After looking all over for a replacement jack and not finding it, I took it apart (the plastic on this one was not glued) and "tweaked" the switch mechanism by bending the moving arm slightly.
Everything is fine now. This procedure is recommended only for those mechanically inclined. I also had to remove the part from the pc board.
20 Feb 2010   #20
bluev
w 7
I installed a driver from the realtec site and it works
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Realtek onboard sound card: Static/Crackling noises
Hey, I recent put together this new rig. I'm using the onboard sound card for my Gigabyte GA-X58A-UD3R Rev 2.0 mobo. The sound chipset is Realtek ALC889. I've updated the latest drivers, but there is crackling/static noise when I play music. Currently I mainly use a 2.1 speaker system. But...
Problems with realtek sound
So I have this problem right now, after installing fresh copy of windows 7 X86 I have sound problems from the beggining. It shows that I have sound drivers installed automatically by windows update, when I play music bars in sound manager is mooving, but i can't hear any sound through my speakers....
RealTek ALC 892 sound problems
I just got a new computer today and have this lovely issue of having terrible sound coming out of my speakers. I have an Asus M4A89GTD PRO, onboard sound RealTek ALC 892. Specs: CPU: AMD Phenom II X4 965 Black Edition CPU Cooler: CoolerMaster V8 RAM: 8GB (4 x 2GB) Kingston HyperX DDR3 1600...
Realtek Sound Problems in Windows 7
I am hearing nothing but pops and clicks in my audio. I have looked all ove this forum, found some solutions, installed all of the latest Realtek audio drivers, un-installed, re-installed, rebooted, updated BIOS and all that, and nothing has been working. Any ideas? Also, I can't seem to get...
realtek sound card
there is sound but the driver not installed correctely
Drivers
