sound problem
Frikster
8:49 PM
Macedonia
i do not know if there is a post about this but i will ask myself
so .. my problem:
i usually run everything on speakers but sometimes i want to switch to headphones
if the game is running and i switch to headphones or the other way around i have no sound and i must restart the game .. why ? how can i fix this
and this happens on every game i play :|
Windows 7 64biti5 6600 3.3 GHz16gb HyperX Fury 2x8gbGigabyte G1 Gaming 1060
Windows 7 64bit
i5 6600 3.3 GHz
ASUS B150M-A
Samsung SyncMaster B2330HD
1tb Toshiba
Corsair builder VS550
SAMA Assasin
A4Tech KB-28G
X7 X-710BK
99 Mbps
Malwarebytes
Nothing at the moment
I believe that in many cases once you've switched to headphones, in order to get back to your system's speakers, you have to either start the game again or worse, reboot your system.
Vista 64 bit and 32 bit (SP2)Intel(R) Core(TM)2 Duo Processor T9400 (2.53 GHz4GB DDR2 System Memory (2 Dimm)512 MB NVIDIA GeForce 9600M GT
Built-in HP
Max
It could be caused by a full-screen application block by your firewall suite..For instance my Norton Suite blocks applications from changing parameters while in game mode or entering full screen applications..
Windows 7 Ultimate x64I76 x 1.5V DDR3 DIMM sockets supporting up to 2...GeForce GTX 580
Alienware
I7
GA-X58-USB3
6 x 1.5V DDR3 DIMM sockets supporting up to 24 GB of system
GeForce GTX 580
Realtek ALC892 codec 2/4/5.1/7.1-channel
NEC Display Solutions E321 Black 32"
1366 x 768
OCZ Colossus LT Series OCZSSD2-1CLSLT1T 3.5" 1TB SATA II MLC Internal Solid State Drive
XFX Black Edition XPS-850W-BES 850W ATX12V
Antec
Zalman
Microsoft
Microsoft
i do not have any kind of anti virus anti spyware detection or protection ... only the standard that i get from windows 7 updates
so ... what do i do ? suggestions ?
and so far i didnt need to restart pc to get my sound back ..
Windows 7 64bit
i5 6600 3.3 GHz
ASUS B150M-A
1tb Toshiba
SAMA Assasin
A4Tech KB-28G
X7 X-710BK
99 Mbps
Malwarebytes
thanks a lot ... i guess no solution
Windows 7 64bit
i5 6600 3.3 GHz
ASUS B150M-A
1tb Toshiba
SAMA Assasin
A4Tech KB-28G
X7 X-710BK
99 Mbps
Malwarebytes
If you have the P5K board, the U.S. boards use the Realtek codec.
If your board is using the same codec, you can download the Realtek software from here Realtek, if you haven't already.
The software gives a jack detection pop-up whenever it detects that your headphones have been plugged in. By pressing OK to the pop-up, you should have sound. The sound shouldn't be disabled because you're using a game, but it could happen.
Let us know!
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
i cant download it
how do i check what series is my p5k ? i used to have that program but not anymore
Windows 7 64bit
i5 6600 3.3 GHz
ASUS B150M-A
1tb Toshiba
SAMA Assasin
A4Tech KB-28G
X7 X-710BK
99 Mbps
Malwarebytes
i cant believe this
ANY suggestions on what i can do ? its very STUPID this bug glitch or w/e it is and its pissing me off that i have to restart the game so i can get sound back -.-
Windows 7 64bit
i5 6600 3.3 GHz
ASUS B150M-A
1tb Toshiba
SAMA Assasin
A4Tech KB-28G
X7 X-710BK
99 Mbps
Malwarebytes
