Solved Another HDMI Audio Problem
Bytowner
7:03 AM
Hi everyone,
I know this topic is a popular one, I've done enough searches on google to figure out I'm not alone with this problem, but still, after a few years, I still can't find the answer. I realise there is a similar thread active right now but my problem is a bit different in that I don't have the option of HDMI in my playback devices at all.
I'm using
Samsung R480 laptop
Intel Core i5
nVidia GeForce GT 330M
High Definition Audio Device (EDIT: when I was updating the drivers Realtek uninstalled itself, this should read Realtek High Definition Audio)
This is a familiar story by now BUT: when I first got my computer my HDMI video and sound worked fine hooked up to my Samsung Plasma. I recall having some problems when I first tried to hook it up, but I figured it out (somehow, this was a couple years ago) and I'm 75% sure it had to do with the drivers. Then I went away for a year, came home and the audio is gone. I have updated all my drivers (I think) and Samsung Update Plus doesn't have anything for me. "Speakers" are the only choice in my playback devices menu and I have show disabled devices checked.
Apologies, I know this comes up often, but I'm at the end of my rope.
Windows 7, 32 bitIntel Core i5NVIDIA GeForce GT 330M
Samsung R480
Windows 7, 32 bit
Intel Core i5
What shows up in device manager? Does it show the HDMI device and does it show it's working properly?
Windows 7 Ultimate x64I76 x 1.5V DDR3 DIMM sockets supporting up to 2...GeForce GTX 580
Alienware
I7
GA-X58-USB3
6 x 1.5V DDR3 DIMM sockets supporting up to 24 GB of system
GeForce GTX 580
Realtek ALC892 codec 2/4/5.1/7.1-channel
NEC Display Solutions E321 Black 32"
1366 x 768
OCZ Colossus LT Series OCZSSD2-1CLSLT1T 3.5" 1TB SATA II MLC Internal Solid State Drive
XFX Black Edition XPS-850W-BES 850W ATX12V
Antec
Zalman
Microsoft
Microsoft
Thanks for the quick response.
Under sound, video and game controllers I have:
Bluetooth handsfree audio
It says the device is working properly.
Samsung R480
Windows 7, 32 bit
Intel Core i5
Did you make sure the cable is good? What about any settings on the tv itself too?
Windows 7 Pro 64bit build 7601 SP1Intel Core I5 3570K 3.4Ghz w/ Zalman CNPS9900...G.Skill F3-12800CL9D-8GbXL ; 4Gx2EVGA Geforce GTX 770 Superclocked
Intel Core I5 3570K 3.4Ghz w/ Zalman CNPS9900NT RT
MSI Z77A-G45 Gaming
Creative Sound Blaster Z
Dual ViewSonic VX2770Smh-LED Black 27"IPS-Panel
Kingston Hyper X 240GB SSD Win8 Pro 64bit 6GB/s Sata III
Intel 335 Series SSD 240GB Win8 Storage 6GB/s Sata III
Intel 320 Series SSD 600GB Storage 3GB/s Sata II
Western Digital Scorpio Black 1TB - Docked via Esata
Coolermaster GX 750W
Corsair Vengence C70
Coolermaster 120mm and Enermax 140mm
Corsair Vengence K70
Logitech G500
22mbps+
Firefox, Chrome, IE
Swan M50W 2.1 speakers
APC UPS
Thermaltake BlacX HDD Dock
Samsung BD Optical Drive
Netgear WNDR4500
Yep cable is fine. Can't see anything in the tv settings that look off. Source is definitely correct.
Samsung R480
Windows 7, 32 bit
Intel Core i5
From what you've mentioned, you don't seem to have an HDMI audio driver installed.
You should see an Nvidia High Definition Audio Device in the device manager.
Your HDMI audio driver would be included in the Nvidia driver package.
It could be as simple as re-installing your Nvidia drivers or maybe not, but you should try that first.
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Thanks p5bdkw. I tried doing a clean install for the NVIDIA drivers, the video installed but the audio did not (just said "not installed"), so I assume my audio isn't going through there (???). Pretty sure I'm not delusional though, it was definitely working before I left home.
Samsung R480
Windows 7, 32 bit
Intel Core i5
Sometimes a system restore may fix the problem. You may have the option of a Samsung restore, as well as a Windows 7 restore.
You can also try using the original drivers from the Samsung support website.
Be sure to select your correct model and model code.
Samsung
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
You get the prize p5bdkw!
I have the Canadian version, so went to the Canadian website and downloaded the first "HDMI" driver. Turned out to be HDMI Audio for NVIDIA and bingo my HDMI option has returned. No idea how it got removed. Thanks so much!
Samsung R480
Windows 7, 32 bit
Intel Core i5
