Windows 7: Problem - Noise front panel
23 Aug 2011   #1
csoyen
I have a Asus P8Z68-V PRO with an Intel i5 2500Kand have a very annoying trouble.
The front panel of my tower (Nox Blaze) when i connect my headphones to audio out make a very low profile noise, it seems like electromagnetic impulses ... When the CPU is used at 100% the noise completely disappear.
Someone can help me with this?
Regards.
24 Aug 2011   #2
fireberd
Check the routing of the cables to the front panel. Dell had a problem a couple of years ago with an XPS model and it turned out the audio cable for the front panel headset/mic was being routed next to the hard drive and as the audio cable was not shielded the hard drive was introducing noise into the headset. Rerouting the cable away from the hard drive fixed the problem.
24 Aug 2011   #3
csoyen
I already try that but didn't work for me :S
Using both front panel audio and back panel: solutions
This possibly should go in the hardware forum since it involves the motherboard as well but being a sound issue I assume here would be better. I have an Asus Xonar DG sound card on an Asus P7P55D-E LX motherboard (and AMD Radeon HD 7800 Series video card) running on Windows 7 Home Premium...
How to disable read audio panel and make the front panel primary?
Hello. I am having a not so common issue of a problematic REAR audio panel jack. The microphone pin got stuck and broken into the rear/back microphone jack and now the OS/driver thinks there is a microphone in the back panel but I just want to be able to make the microphone work on the front panel...
Front mic panel problem, says its unplugged
Ok im at wits end! Im pretty sure i got this to work before. But i forgot how to do it. My front mic panel doesnt work ive spent hours trying to find the solution but failed :cry: The front panel used to work before so im sure it shouldnt be a hardware issue. About six months ago i was tweeking...
Hardware & Devices
front panel jacks
When connecting the front panel (mic, headset) of a case to the mobo, is it possible to plug it in backwards and still have it work. I ask only because in my VIA HD screen it lists the back panel and front panel. In it the green jack is highlighted where my speakers are connected to. In the front...
Fatality Series Front Panel Problem
Hi guys! Just had my nightmare barebones bundle shipped back to me after a repair to find there is seemingly no power to the I/O front panel for my Fatality Series Sound Card as the lights don't power up. This was working seemingly fine prior to the transport. The headphone jack works and the...
Front panel..
Please Help me! I can't make play back and front :( Ihave plugged both and fron and back panel but still have a problem... And my Realtek HD audio manenger looks different... How i have make that with this? there is no Folder option... What should i do on that? :eek: EDITED: Oh ya then i...
