Windows 7: Sound Problems
24 Aug 2011   #1
twitching69
windows 7 ultimate
Sound Problems
I have an IMEDIA D2315 AIO and recently upgraded from the vista o/s that came with the comp to windows 7 ultimate.
I now have no sound coming from the built in speakers in my monitor (Viseo 191ws). Packard bell download site is complete double dutch, i cant understand it at all. Plus i dont see anything to do with my computer.
I have been into device manager and under sound tab all i see is High Def Audio Device. I can get sound if i plug speakers into the tower unit, but was sure i had sound from the built in monitor speakers.
Any idea what i am doing wrong Please?
24 Aug 2011   #2
mrdemon
Windows 7 Home Pre
Does the Speakers on the Monitor have a AMP. If not there may be your problem. Try turning your Volume Right Up and see if you get anything. If your sound works on other speakers then its your Monitor, maybe you have pulled a wire out, there are many many options here.
24 Aug 2011   #3
boohbah
im willing to bet you have a realtek sound card. go back to control panel and ignore the sound tab and look for realtek audio sound manager or something like that,i cant remember the correct wording ,im on lappy atm and cant get to desktop for exact title.
 Sound Problems
5.1 sound problems.
Hi guys Well, I have motherboard Asus P5Q3 deluxe with AP with soundMAX HD. Driver is up to date (from asus website). Aslo, I have 5.1 sound system. When Im doing the test everything works just fine. All 5 speakers are working. But, when Im starting to listen to the music from my hdd, rear...
Sound problems
I'm new on this forum so Hello everyone :D Few days ago i installed my new windows seven professional x64 and i can't solve my sound problem on sistem 5.1 My motherboard is from intel => DP35DP and my sistem is Logitech X-540 i've tried to install all latest drivers from my motherboard and i...
Sound Problems
When I run video (from MSNBC site) or a song (from ITunes) the sound cuts out after about 2-3 seconds. If I adjust the volume the sound comes back in then cuts out again after 2-3 seconds. Any ideas?
Music, Pictures & Video
sound problems with Realtek ALC 882 sound card
I have a HP Media Center PC. the Model number is a1412n I am dual booting xp and windows 7, and in windows 7 I am not getting any sound. When I went to check it out, I realized that the computer was only recognizing the front audio jack. So i plug my speakers into the front jack but it still says...
I'm having problems with my 5.1 sound!!!!
Okay here is whats been happening I awhile back i was using the Windows 7 RC i recently got Windows 7 Ultimate which is perfect but except for one thing my sound is not working properly i have logitech 5.1 sorround sound speakers when i play music it wont work no sound even on videos but when i...
Sound Problems
Hi I just got Windows 7 installed fresh install I never thought I would have sound problems. I have an on board sound also a PCI SoundBlaster Live CT 4670. I removed the PCI SoundBlaster Live due to could not find any drivers for it so. I enabled in my bios the on board sound it is a Realtek...
