Making sound work.. switching between speaks and headset
More issues with this ****ing shitty operating system that is Windows 7 Pro 64bit.
I need to get sound working. I have two sound devices that I need to use.
1) A headset. This is USB based.
2) Speakers. These use jacks. No USB. No software.
Yes, they work. Windows has ****ing issues with them.
I need to do the following:
1) Make both of them work.
2) Be able to switch between them without shutting down Windows 7. In Vista I used to right click on the speaker/volume icon in the task bar and then click "Playback Devices". I had the option to choose both. When I wanted to use speakers, I would right click and disable the USB headset. It would default to the speakers. I could then listen to audio with my speakers. If I wanted to switch back to my head set, I could do that as well. The method would be the same as described above.
Is this possible in Wodoze 7 Pro 64bit? If so please instruct me on how to do this.
