Making sound work.. switching between speaks and headset
ABC190
6:58 PM
More issues with this ****ing shitty operating system that is Windows 7 Pro 64bit.
I need to get sound working. I have two sound devices that I need to use.
1) A headset. This is USB based.
2) Speakers. These use jacks. No USB. No software.
Yes, they work. Windows has ****ing issues with them.
I need to do the following:
1) Make both of them work.
2) Be able to switch between them without shutting down Windows 7. In Vista I used to right click on the speaker/volume icon in the task bar and then click "Playback Devices". I had the option to choose both. When I wanted to use speakers, I would right click and disable the USB headset. It would default to the speakers. I could then listen to audio with my speakers. If I wanted to switch back to my head set, I could do that as well. The method would be the same as described above.
Is this possible in Wodoze 7 Pro 64bit? If so please instruct me on how to do this.
Vista
Vista
Hi
You can switch between different devices but not have 2 active at the same time. Select the device that you want active and then use the 'Set Default' buton, a green tick should appear next to the active device.
You can then switch by doing the same process. You will find that some applications will not pick up a change in default device without restarting.
Regards
UKMedia
Windows 7 Ultimate 64Bit (SP 1)Intel Core i7 4770K OC32GB 1600Mhz DDR3MSI GTX580 Twin Frozr II/OC and NVIDIA GTX 970
Self Build
ASUS Maximus VII Ranger
32GB 1600Mhz DDR3
On-Board and Soundblaster Recon 3 D headset
x2 Flat screen 21" LG displays + x1 LG W2363D (3D)
5 internal Hard Drives:
1 x WD 120GB Solid State
4 x WD 1TB (CAVIAR BLACK 1TB 32MB 7200 SATA) as Raid 5 array
Dark Power Pro 10 1200W
CoolerMaster HAF 932 Case - Black
Thermaltake Contac21 cooler
Cyborg
Razor Mamba
0.5 Mb - (Benefits of rural location!) & 24 MB Sat
Teaming 2 GB network connection to Wired 1GB switch.
Connected to 37TB (Raid 5) of network storage on a wired 1GB lan.
(Mixture of internal hard drives, 1TB, 2TB, 4TB & 16TB Terastations)
