Sound Problem
  1. Posts : 10
    Windows 7 x64 Professional
    Sound Problem
    I have tried to play mpegs and Avi files on Nero Showtime (Nero 7 ) and also on Divx 8, Realplayer and Quicktime but I get no sound.
    I do get sound on Win Media Player only.
    I installed Klite codec pack for Win 7 64bit.
    Do I have to install the 32bit codec pack for the 32bit programs to work?
    Any advice would be apreciated.
  2. Posts : 6,668
    Windows 7 x64
    The codecs aren't dependent on bit that applies to the additional software klite installs in addition to the actual codecs.
    That's part of the reason I quit using klite sometime ago and started using the cccp pack instead.
    I doubt it's a codec problem though as they wouldn't work in media player either if that was the case.
    Do you get sound using this program.
    VideoLAN - Official page for VLC media player, the Open Source video framework!
    sorry to ask you to install yet another player, but it's the only one I know of that works independently of the system codecs.
  3. Posts : 10
    Will give it a try and let you know how badly I muff it
  4. Posts : 10
    It's alive, it's alive
    Thanks for that
