Solved Sound Problem
Alibaby
7:15 AM
I have tried to play mpegs and Avi files on Nero Showtime (Nero 7 ) and also on Divx 8, Realplayer and Quicktime but I get no sound.
I do get sound on Win Media Player only.
I installed Klite codec pack for Win 7 64bit.
Do I have to install the 32bit codec pack for the 32bit programs to work?
Any advice would be apreciated.
Windows 7 x64 ProfessionalPhenon II x6 1100T8GB Kingston HyperXGigabyte GTX-580
Self
Phenon II x6 1100T
GA-990FXA-UD5 Gigabyte
8GB Kingston HyperX
Gigabyte GTX-580
Onboard
17 inch LG LCD
WD1002FEAX 1 TB
Bliss 1000 watt Gaming PSU
Thermaltake Eureka Server Tower
2x 100mm case fans
The codecs aren't dependent on bit that applies to the additional software klite installs in addition to the actual codecs.
That's part of the reason I quit using klite sometime ago and started using the cccp pack instead.
I doubt it's a codec problem though as they wouldn't work in media player either if that was the case.
Do you get sound using this program.
VideoLAN - Official page for VLC media player, the Open Source video framework!
sorry to ask you to install yet another player, but it's the only one I know of that works independently of the system codecs.
Windows 7 x64Intel i7 2600kG.skill Ripjaw 16gigs @ 1866Nvidia gtx580 (evga)
Insane hobo technologies. ;-)
Windows 7 x64
Intel i7 2600k
Asrock z68 extreme 4 gen 3
Integrated HD audio + hdmi
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
1 western digital 1tb (eSATA)
1 Seagate 1tb (eSATA)
Zalmann
Microsoft wireless 3000 (v2)
Will give it a try and let you know how badly I muff it
Self
Phenon II x6 1100T
8GB Kingston HyperX
Gigabyte GTX-580
Onboard
17 inch LG LCD
WD1002FEAX 1 TB
2x 100mm case fans
It's alive, it's alive
Thanks for that
Self
Phenon II x6 1100T
8GB Kingston HyperX
Gigabyte GTX-580
Onboard
17 inch LG LCD
WD1002FEAX 1 TB
2x 100mm case fans
