Windows 7: Front audio Panel doesn't work (ASUS P7P55D motherboard)
19 Sep 2011   #21
Win7 Home Premium 64 bit
Quote   Quote: Originally Posted by questionesse View Post
umm - how did we come up with the realtek?
Asus states it's a VIA Chip...
ASUSTeK Computer Inc. - Motherboards- ASUS P7P55D
VIAŽ VT1828S 8-Channel High Definition Audio CODEC
- Absolute Pitch BD192/24
- DTS Surround Sensation UltraPC
- BD audio layer Content Protection
- Supports Jack-Detection, Multi-streaming, Front Panel Jack-Retasking
- Optical S/PDIF out ports at back I/O
I'm just saying on my MB which uses realtek audio I had to disable front panel jack detection to get my mike and head phones to work. Maybe your board has a similar setting with the VIA chipset.
19 Sep 2011   #22
win7 prof.
I'm talking in general since we're figuring with the realtek driver since quite a while in here...
19 Sep 2011   #23
Microsoft MVP
Windows 8.1 Pro with Media Center 64 bit
Somebody assumed it was Realtek, and nobody (except you) double checked to see if that was correct.
Probably because they have an ASUS board with Realtek audio.
My Asus M2N68-AM SE2 is Realtek but my Asus M4N68T-M V2 is VIA.
19 Sep 2011   #24
win7 prof.
so which VIA driver do I need then?
19 Sep 2011   #25
Microsoft MVP
Go to the downloads section on the ASUS web site for your specific model of motherboard and get it there. If that doesn't work then try downloading the correct driver from the VIA web site. I went to ASUS.com but it lists several different model of the P7P55D, so I'm not sure which one exactly is yours. There should be a driver on the CD that came with the motherboard.
20 Sep 2011   #26
win7 prof.
It WAS the realtek driver instead of a VIA one - omg, this is the funniest solution of such a problem ever!
Thx for bearing with me and trying to dig up new possible solutions all the time!
Š Designer Media Ltd
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
