Windows 7: Front audio Panel doesn't work (ASUS P7P55D motherboard)
27 Aug 2011   #1
questionesse
win7 prof.
Hey there,
I'm using the onboard sound of my ASUS P7P55D motherboard.
The back audio connectors work fine, but I somehow can't use the front panel that I connected to the mobo (yellow cable).
Is there a trick or any setting to activate it with win7 professional x64?
I also tried changing to AC97 in BIOS, didn't help...
thx!
27 Aug 2011   #2
stormy13
Microsoft MVP
Win 7 Ultimate x64
Check which it is that the csae has as they are wired differently between HD Audio and AC97,
It is also possible that that fpaudio block is wired wrong and neither will work. If that is what it is it will take pulling and reseating the various wires in the block; not easy but can be done.
27 Aug 2011   #3
questionesse
win7 prof.
ah - I just added the BIOS option while you answered!
thx for your fast reply though!
I am not sure what kind of front panel that is - how to indicate that? The problem is that I can't access the back connector of the front panel that easily without deconstructing almot the whole system...
If I get that right, HD audio and AC97 plug into the same connector, so the cable is in the right spot either ways, isn't it?
27 Aug 2011   #4
stormy13
Microsoft MVP
Win 7 Ultimate x64
Cable's in the right spot, but can't tell from looking at it whether it is AC97 or HD Audio. If you don't have it check your case manufacturer's site for the manual and hopefully it will say which it is supposed to be.
27 Aug 2011   #5
questionesse
win7 prof.
found it, it's a CHIEFTEC BA-01B-B-B-400
says 2x USB2.0, 1x IEEE 1394 Firewire, Mic-in, Line-out (HD-Ready)
so the BIOS Setting was correct. Anything I need to activate in the audio settings?
thx
29 Aug 2011   #6
questionesse
win7 prof.
any other ideas? I'm not that familiar with audio settings in win7 - but there are a lot of options so I assume it could be some wrong setting...
29 Aug 2011   #7
Sardonicus
Windows 7 Home Premium 64 bit
You've set the Front panel type to AC97, as mentioned.
You probably need to install the Realtek AC97 codec software.
I'm not sure if you can use it with the Realtek HD Audio software, so you may need to uninstall it.
You may be able to use both codecs together or it may be one of those either/or situations.
I don't know.
Good Luck!
http://www.realtek.com.tw/downloads/
29 Aug 2011   #8
stormy13
Microsoft MVP
Win 7 Ultimate x64
Quote   Quote: Originally Posted by p5bdkw View Post
Doesn't work that way, the onboard audio still needs the HD driver. The only reason for that option in the bios is so that the fpaudio connectors on the motherboard can be connected to the front panel audio on the case regardless of how the case is wired.
Don't have anything here that has Realtek audio but found this elsewhere,
Try it by matching that setting with the one in the bios until you hit the combo that works.
29 Aug 2011   #9
alphanumeric
Windows 10 Education 64 bit
On my case the cable from the front panel audio jacks has two plugs on it. One is AC97 and the other is HD Audio, each one is wired different. I have to match the BIOS setting to the plug I use.
This might help.
AC'97 and HD audio front panel layouts
EDIT: If you can look though the manual fro your motherboard and see if it gives the pin out for the audio header. Then do the same thing with your case manual and compare the two to see if they match.
29 Aug 2011   #10
questionesse
win7 prof.
umm - I don't have any Realtek codec installed - didn't know I need that for onboard sound...thought they were making soundcards.
That's the one you mean? Realtek AC'97 - Freeware - EN - Download.CHIP.eu
my hardware manager mentions one HD audio device and an ATI HD audio device, nothing from realtek.
I don't get the jacks part - there is just that one for audio, so what should be wrong?
thx guys!
No front Panel audio detected but Rear Audio works on Asus P8H 61-M LX
My front USB slots work and every connector on the rear works fine yet when i plug headphones into the front audio jack and nothing is detected. My Bios are updated to the latest version, i have also tried switching to AC97 but makes no difference. Swapping between HDMI and s/pdif doesn't also...
Asus onboard audio no longer working since enabling front panel audio.
My audio rear outs used to work, but even so, i was primarily using hdmi out from my video card. I was also diagnosing BSODs at the time and sent my mobo back to asus for an rma. When it got back, I placed it in a different case and attached the font panel audio. Due to a new living...
front panel audio jack doesnt work after sleep mode until restart
I have realtek ALC898, part of gigabyte Z77 UD5h mobo, windows 7 ultimate 64bit. Rear jack speakers always work, sound always works. But after sleep, the front panel audio jack does not work, ie headphones silent. Workaround 1) go to device manager, disable realtek high definition audio, then...
Hardware & Devices
front panel audio does not work
Hello everyone I have an hp media center PC m7350n and I have upgraded from Windows XP to Windows 7, I also installed a new graphics card AMD Radeon HD 6450. When I was working on Windows XP my front panel audio was working for my headsets and microphone. Since I've upgraded my headsets and...
Front panel audio connections to motherboard Not Working!
Building a new rig, but for some reason there is no sound when I boot the machine up, the sound always come's from the front panel audio connections to motherboard and case Hd audio or AC97 wires which are both compatible on my motherboard. The gaming case is a Antec 900, it all seems wired up...
Front Audio Doesn't work - Windows 7
Hello, I just upgraded from windows XP to Windoes 7 & installed all the latest available motherboard drivers from intel. Everything is working fine but there is no audio via my front audio jack. Even Realteck Audio Manager is even not recognizing any pluggen in jack in the front audio...
