Windows 7: no sound please help
28 Aug 2011   #1
waxykool
windows 7 home premium 64bits
I have a windows 7 home premium installed on my iMac, but for some strange reason te sound wont work. if i switch to mac it does work and in windows all drivers looks OK. no yellow sign by the d sound card in control panel and as far as i know the settings are alright except i have gotten something wrong which i cant seem to figure out at this point but its driving me crazy any suggestions PLEASE.
28 Aug 2011   #2
mrdemon
Windows 7 Home Pre
Mac? Im guessing onboard sound and not a Child card. This case you need to Find out that your motherboard is, I use CPU-z Once there and running goto the Motherboard tab ,
Once you have the motherboard, goto there site and download the Drivers from there.
28 Aug 2011   #3
waxykool
what do i need this motherboard detection for? i have a sound problem
28 Aug 2011   #4
Golden
Microsoft MVP
Windows 7 Ult. x64
You need to know your motherboard information since demon believes its an on-board soundcard issue. If it is, it might allow you to get updated drivers that might solve the problem.
In fact, you should provide all your hardware details since that helps us help you quicker. You can use CPUZ, or you can use this tool:
System Info - See Your System Specs
Regards,
Golden
01 Sep 2011   #5
ahmedelshawarby
win7 32 bit
same problem with me !! no sound .... i'll upload some pics from my pc to help
01 Sep 2011   #6
ahmedelshawarby
win7 32 bit
when i play something !
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one... When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound. I would like to mute the Windows 7 sound that happens when I adjust the sound,...
