No Audio OUTPUT Device is installed
eddyeshef
5:08 AM
I upgraded my computer to Windows 7 Ultimate 32bit and im having problems installing the Realtek sound driver that's compatable with my computer. Every time i install it it says i dont have acces to memory location. I tried every solution on the internet but nothing worked. Please help me, im desperate!
While you are waiting any chance you can give us your system specs, and what driver you are attempting to install (link to it please)
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
Realtek - here's the driver and by far as i know i have a intel pentium 4 , 3.00 Ghz and a ASUS motherboard (i dont know what model)
Uninstall the driver and check the delete the driver software box from the device manager and reboot.
Windows should install the generic driver.
Try installing the Realtek software.
If successful and you still have no sound, unplug the speaker cable.
Plug in the speaker cable and wait for the jack detection pop-up.
Press OK.
Hopefully you should have sound.
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
I uninstalled the driver and rebooted but a message pop's up : The device was not installed properly.
Uninstall Realtek from Programs and Features in Control Panel.
Windows 7 Home Premium 64bitIntel Core i3-2310M8GBIntel HD3000
Acer Aspire 5750
Intel Core i3-2310M
Acer OEM
8GB
Intel HD3000
1366x768
320GB Toshiba
