Windows 7: CPU to TV/Surround Sound Receiver Issue
02 Sep 2011   #1
Indecl
64 Bit Windows 7 Home Premium
After spending an hour or so trying to read through the 1,000's of HDMI sound issues, I decided to just register and post my problem because every "solution" I found is something i've already tried.
I have a HDMI cable going from my Desktop tower to my receiver, with HDMI output already as my default for sound. I get nothing, no music, no test sounds, nada. I tried to update my sound/video drivers and all of them said they were up to date. The receiver is on the correct input setting.
I also tried to back-feed it through my TV, with the HDMI going to the TV first, with my Digital Optical Audio cable running from my TV to my receiver. Again, no luck still dead as a doornail.
My Media Player is already set to playback through HDMI, and I cannot get sound from anything on my computer period.
Does anyone have a clue what to do? I'm out of ideas and honestly out of patience. Any help would be appreciated.
02 Sep 2011   #2
fireberd
What video card do you have? Does it generate it's own HDMI audio or does it use an S/PDIF connection to the PC? (and if it does use the S/PDIF connection, do you have it connected).
Filling out the full "My System Specs" would really help.
If you are using certain Dell desktops, they have an HDMI port on the rear but that is only HDMI Video and not Audio. On these models you must use a separate Video card that does have HDMI audio.
02 Sep 2011   #3
Indecl
I have a Nvidia GeForce GT 220, and it has an HDMI output. I only see VGA/DVI/1 HDMI on the outside of the card. The Desktop is something I bought off Newegg awhile ago, it's not really any brand.
Asus Board, Phenom II, GT 220, 4 GB RAM, etc.
The option to select HDMI appears when I plug the cable in, but it doesn't appear to do anything. I've gotten it to do video to the TV, sound is my issue.
02 Sep 2011   #4
Sardonicus
Windows 7 Home Premium 64 bit
You might want to sign in to Newegg and look at your purchase history (yes, they keep it) and see if your card does use the S/PDIF connection. Even with an HDMI port, if your card was intended to use S/PDIF pass-through and you don't have it connected, you won't get sound through HDMI as Fireberd mentioned.
Here's an example of a card that use S/PDIF pass-through......
ASUS EN9400GT-1GB Geforce 9400GT Half-Height Videocard Review - PCSTATS.com
02 Sep 2011   #5
Indecl
NVIDIA GeForce GT 220 PCI Express 2.0 x16 is exactly what NewEgg says, trying to find the other parts out. Used the purchase history to fill in more of the computer specs Fire said would be nice to have on my profile. Doubt that'll help much, and i've tried simply google'ing my video card to see if it does have this S/PDIF connection, and the only thing i've found thus far is people getting sound from 2 speakers instead of 5. That's not my problem, my problem is I haven't gotten any sound from any speaker.
Edit: Ok, Nvidia's website says my card is HDA, SPDIF as Audio Input for HDMI
02 Sep 2011   #6
Sardonicus
You'll need the S/PDIF cable to get sound, then.
02 Sep 2011   #7
Indecl
Quote   Quote: Originally Posted by p5bdkw View Post
I was looking inside my case for a SPDIF out on my motherboard, I found the label for it but the closest connector to the label is a "COM1" plug. On my video card I can see a plug that looks similar to the SPDIF connections i've found looking around on the net, but I cannot see where the wire goes. Guess i'll have to open the tower up when I get home. Any tips/hints/whatever for figuring all this out so I can use this SPDIF mumbo-jumbo?
02 Sep 2011   #8
Sardonicus
HWiNFO32 Download
ASUSTeK Computer Inc. - Motherboards
Get your exact mobo info, download the manual and you'll see exactly where the pins are.
02 Sep 2011   #9
Indecl
HWiNFO32 Download
Came home, found the plug on my motherboard. Found out the connector I saw on the video card was for something else, couldn't find a SPDIF output on the video card. Nvidia's website says my card has SPDIF, so naturally i'm confused. I did some more research and apparently no one knows if my card can or can't do it. Some things say the card doesn't have SPDIF, others say it's integrated into the card and you don't need an adapter. Any other ideas?
03 Sep 2011   #10
fireberd
Who is the actual manufacturer of the Video Card? There are several different vendors that make that card and you need to go to that vendor's web site and look at their spec's for that card to determine if it has built in audio or does require the external S/PDIF connection.
S/PDIF Optical out - No sound from receiver (onboard and sound card)
I've got an Asus Crosshair V Formula motherboard that I couldn't get any sound on my Onkyo HT-R550 receiver via the onboard optical output (Win 7 Ultimate 64 bit OS) I was planning on getting a nicer sound card anyway, so I bought the Asus Xonar Essence ST. Installed that sound card but alas, I...
surround sound issue
Recently, windows did an update. Since then, I lost my surround sound, (realtek drivers). Every time I try to change the settings to enable it again, I lose all sound and have to uninstall then reinstall realtek. If I don't touch the settings, I get sound through the monitor, but once I try and...
Surround Sound Amplifier/Receiver
Hey there fellow members I know this is a little off topic compared to most of the threads on here, But I am not quite up on the Surround Sound side of things, I purchased a Sony 5.1 system the model number is SA-CRW55/SA-CRW33 it comes with everything but the Amplifier/Receiver and I am uncertain...
Chillout Room
Another 5.1 Surround sound issue for Win7
I'm decent with computers, but don't know much about sound cards, so I'll be using some screen caps. I just bought some new speakers, the Logitech Z506s (front left/right, center, rear left/right, subwoofer). They are connected to laptop via a single cable, jacked into my single audio out. ...
No surround sound through HDMI to AV Receiver
I am connecting my laptop to my AV receiver via HDMI cable. With both streaming video (netflix, hulu) and various video formats, I am not getting any surround sound. Is there a setting in Windows 7 I am missing? Thanks for any help!
Sigmatel IDT 5.1 Surround Sound Issue
I finally tracked down why my surround sound wasn't working. I went into the IDT control panel (not Windows 7 Sound and Hardware) and saw that the options for speakers were switched to Stereo Speakers, so I changed them to 5.1, but it instantly changed back to Stereo. Now everytime I try to switch...
