Windows 7: No audio output device installed
02 Sep 2011   #1
sdraza1
MS Windows 7 Home Premium 32-bit SP1
I bought a generic computer. It had windows vista installed and it used to display a message that No audio output device is installed . I recently installed windows 7 home premium 32 bit on it but it still says the same thing. I went to properties of it and found following error message.This device cannot start. (Code 10).
System specifications are
manufacturer EMACHINES
SYSTEM MODEL T5010
TYPE X86 BASED PC
BIOS VERSION INTEL CORP. AG91510J.15A.0816.2005.0214.1818, 14/02/2005
SMBIOS VERSION 2.3
Hardware Abstraction Layer version= 6.1.7600.16385
Sound Device Name High defintion audi device
Manufacturer Microsoft
status error
PNP device id HDAUDIO\FUNC_01&VEN_10EC&DEV_0880&SUBSYS_08600000&REV-0900\4&....
DRIVER C\windows32\drivers\hdaudio.sys(6.1.7600.16385, 297.00 KB (304,128...
I downloaded and installed the intel chipset driver and then the RealTek driver from manufacturer website but that didn’t solve the problem.
If I buy a sound card from a computer store, perhaps I will also get CD for driver installation with it. If I put sound card in my system and install driver, will the sound function start working. thanks for the help
02 Sep 2011   #2
tman69
win7 ultimate 32bit
Sound is possibly disabled in the BIOS.
enter BIOS and check under advanced chipset features
02 Sep 2011   #3
karlsnooks
sdraza,
Win 7 is not eXPired. If the sound card you buy is not some off-the-wall el-cheapo card, then MS will automatically install the needed drivers.
I'd like for you to help us by doing following, precisely as written:
UPDATE YOUR SEVENFORUMS SYSTEM SPECS
User CP (3rd item in the top menu bar) |
Your Profile (left-hand column, Edit System Spec |
To gather info, use
Speccy - System Information - Free Download
or SIW or the System Info tool,
Use System Info to see your System Specs
Please add the word laptop or desktop or netbook to the
“system manufacturer” block.
Provide full windows version info, for example:
MS Windows 7 Ultimate 64-bit SP1
Use the “Other Info” block for Optical Reader,
Mouse, touchpad, wifi adapter, speakers, monitor, etc
Scroll down and click on the SAVE CHANGES button.
03 Sep 2011   #4
sdraza1
Quote   Quote: Originally Posted by karlsnooks View Post
sdraza,
To gather info, use
Operating System
Intel Pentium 4 519K
Prescott 90nm Technology
RAM
1.00 GB Dual-Channel DDR @ 106MHz (2.5-3-3-7)
Intel Corporation D915GAG 65 °C
Graphics
SyncMaster (1400x1050@60Hz)
Intel(R) 82915G/GV/910GL Express Chipset Family
313GB Seagate ST3320613AS ATA Device (SATA) 42 °C
Optical Drives
HL-DT-ST CD-RW GCE-8483B ATA Device
Audio
High Definition Audio Device
04 Sep 2011   #5
karlsnooks
1 GB of ram is under what I call the practical minimum of 2 GB.
No sound in Windows
Open the Hardware and Devices troubleshooter
04 Sep 2011   #6
sdraza1
No sound in Windows
I went to both links and ran fix it but problem is not solved. Now perhaps the only option is to buy a new sound card and install it. Right? thanks
04 Sep 2011   #7
karlsnooks
Definitely a "sound" idea.
No Audio Output Device is Installed
I believe this is an issue regarding an update. I had this issue before and did a system restore to back before I had installed a certain program, and the issue went away. Now however, I do not have a restore point that will go far enough back. I started up my computer today and I was hit...
Drivers
no audio output device installed
This is my wife's sony vaio, and she has had this problem with no sound on her laptop, when checking the volume control it says no audio output device installed. In device manager it says that she has Intel display audio. I need major help here please.
No AUDIO OUTPUT DEVICE IS INSTALLED
No AUDIO OUTPUT DEVICE IS INSTALLED, this is the message l got on sound icone since l installed windows 7 l have downloaded it several time the latest one it shows on control panel but not on device manager, l guess this is not really installed but l keep installing it and restat the laptop...
No audio output device installed...Tried everything, need some help.
All fixed...Hardware issue. Stripped it down and rebuilt it. Booted up and installed the drivers....woohoo I have sound again...lol Hi, I have had this problem now for a couple of months. What I have tried: Reinstall windows 7 Update bios Install the realtek high definition audio...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
Hello, Can anyone help me get my onboard sound to work? Newly put together computer, and after trying drivers on CD, on Gigabyte home page, and newly posted 2.54 from Realtek site, I still have no sound. Ive tried everything I can think of driver wise, toggled BIOS option for Azalia codec...
