Solved Front audio headphone jack reversed stereo...
quanzaboy
7:13 AM
Realtek on-board sound channels (L/R) are REVERSED!
I have a Gigabyte GA-P55-UD5 motherboard with on-board sound by Realtek, and my case is Thermaltake's "Element G".
I connected the front panel audio cable to the designated connection on the motherboard, however, whenever I plug-in my headphones, the stereo is reversed! Meaning that the headphone for the Right ear is playing the audio channel for the Left ear, and vice versa.
I end up having to wear my headphones in reverse to enjoy correct stereo sound.
I checked the front panel audio connection to the motherboard, thinking that maybe I plugged it in the wrong way or something, but apparently there is only one way to plug it in.
My first guess was that this was a design flaw with the case, and that they mixed up the audio channel connections in the front panel. However, when I plugged my headphones DIRECTLY to the REAR audio jack, it's exactly the same story!
The fact of the matter is that the on-board audio is mixing up the stereo channels! I actually remember that on my previous computer with on-board audio it was the same exact problem.
1) Is this a known issue with on-board sound cards in general?
2) Most importantly, is there any way I can fix this in Windows 7? Reverse the stereo channels so that they are outputted correctly?
Thanks in advance!!
Windows 7 Ultimate x64 (SP1)Intel Core i5 760 OC @ 4.0GHzA-Data 4GB DDR3 OC @ 1600MHzASUS ENGTX580 DCII
Gigabyte GA-P55-UD5
ASUS ENGTX580 DCII
Realtek HD Audio (On Board)
Dell 2209WA
OCZ Vertex 3 SSD 120GB | WD Caviar Blue 500GB | WD Caviar Green 1000GB
600W
Thermaltake Element G
Noctua NH-D14
12Mbps
Never mind. I tried a different pair of headphones and there was no problem. Apparently my cheap "Sony" headphones were just defective.
Gigabyte GA-P55-UD5
ASUS ENGTX580 DCII
Dell 2209WA
600W
Noctua NH-D14
12Mbps
Bah! i just spent the last 2and a half hours googling the issue ;)
Hewlett packard/p6512uk
FOXCONN 2AA9
2x2gb
ati radeon HD 5450
samsung lcd tv 32"
1360x 768
air!
wireless hp
wireless Hp,optical
1.10mb/s
boohbah you forgot to mention the fun you had Googling.
lol yeah I googled the crap out of this issue until finally I found a reference by someone on some forum complaining about a similar problem until he replace the cable he was using and solved the issue. So I tried using a different pair of headphones and viola! Problem solved!
Gigabyte GA-P55-UD5
ASUS ENGTX580 DCII
Dell 2209WA
600W
Noctua NH-D14
12Mbps
i was only joking , did spend about half an hour though , the amount of suggestions on forums to turn the headphones around were unbelievable. why the hell you would do that if you have ergonomically designed headphones i dont know.
FOXCONN 2AA9
2x2gb
ati radeon HD 5450
samsung lcd tv 32"
1360x 768
air!
wireless hp
wireless Hp,optical
1.10mb/s
