Windows 7: Sound card sounds no better than integrated motherboard audio?
09 Sep 2011   #1
XGamer95
Windows 7 Ultimate 64-bit
I purchased the Creative Sound Blaster Audigy SE 7.1 Channels 24-bit 96KHz PCI Interface Sound Card, a cheap, $30 card, and was expecting some improvement over my computer's integrated motherboard audio (Dell XPS 420), but I can't really tell the difference between the two. Is it possible for the card not to sound any better than my computer's integrated audio? I'm using the Logitech Z523 2.1 speaker system.
Sound card: Newegg.com - Creative Sound Blaster Audigy SE 7.1 Channels 24-bit 96KHz PCI Interface Sound Card
Speakers: Newegg.com - Logitech Z523 40 Watts RMS 2.1 Speaker System
09 Sep 2011   #2
Zepher
Windows 7 Ultimate 64bit
yes it's possible.
09 Sep 2011   #3
Wishmaster
You may try adjusting some of the cards settings to see if it helps.
Im not sure about that exact card but ...
I have the Xi-Fi Extreme Gamer and Klipsch Pro Media Speakers.
The difference between the sound card, and onboard audio is huge.
Theres just no comparison.
My onboard sounds muddy & dull in comparision.
A large portion of the sound quality will be from how well the speakers can reproduce the audio. Not that those are bad, I've never heard them.
So if adjusting the sound cards setting does nothing to improve it, its possible it could be that particular sound card, the speakers themselves, or a combination of both.
It is probably fair to say, some modern onboard sound these days is just as good or better than the cheaper sound cards.
VIA VT8237R Integrated Direct Sound AC'97 audio for windows 7???
Does anyone know if the onboard sound can be made to work? MSI USA PM8M-V • VIA® VT8237R Chipset - Integrated Direct Sound AC'97 audio. I have looked and some say no, some say yes. Like this here, where they mention this forum. windows 7 via vt8237a 1708 codec sound driver ? - VIA...
AM3/+ Motherboard with Integrated Graphics
Is there a motherbaord that offers integrated graphics within the socket am3/+ region?
Hardware & Devices
What ext video card takes SPDIF audio from ext sound card?
Presently I have to use onboard sound card to have audio through HDMI output from video card. The external sound card installed is Xonar DG and it comes with SPDIF output header to be interfaced with video card. But I do not see no such header on the video card. I wonder what video card has such an...
Graphic Cards
Motherboard supports integrated GFX card processor doesn't?
I've been reading the specifications of my mobo and processor.. (Available in specs) Motherboard allows integrated graphics card: :ar: ARK | Intel® Desktop Board DG41WV But Processor doesn't: :ar:...
Hardware & Devices
Motherboard won't detect my sound card
I recently changed my OS to Windows 7 x86 from Windows XP on my podunk 2002 Gateway. Suddenly, it wouldn't play sounds and said there was no sound device. I thought I needed a driver for my Creative Sound Blaster card but I don't think any of my PCI slots are working because it won't even recognize...
Hardware & Devices
No sound on Intel 845 board in a MPC ClientPro345.. Soundmax Integrated Digital Audio
Have tried numerous drivers
