Enable pc speakers?
  1. Posts : 1
    windows 7 64 bit
    Enable pc speakers?
    Hi guys
    My minijack output has been damaged, so my computer thinks that the minijack always is plugged in, and my pc speakers won't work, how can i fix this?
    Disable the audio output plug, and enable the pc speakers?
    i know its possible, cause its possible in a software on linux..
    but i just don't know how to change this, i been trying to look all over registry but with no luck.. (HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318})
    i have windows 7, 64 bit, realtek high definition audio
    Thanks!!
  2. Posts : 752
    Windows
    Hello there, abdoll.
    Follow these steps and re-assing a different output to your speakers.
    Realtek HD Changing Jack output reassignments ( FIX )
    I'm guessing that is the issue you're having right now.
    Cheers.
