- Local time
- 10:38 PM
- Messages
- 173
I can't seem to find a sound card on Newegg.com that fits my shopping standards. So, here I am coming to the experts. I will list my rig specs atm, and my desires, and let us see if we can find something that meets my stringent criteria. Most items I search for on Newegg are lots of reviews, 4-5 stars, brand name, compatibility etc. And the one I can't seem to ever get right is it looks like none of these sound cards say Windows 7 compatible anywhere on them. And since almost none of them say compatible, I would normally assume they all might be, but I have seen an exceptionally large amount of reviews saying "Generic example sound card X100 has windows 7 compatibility issues!" So the biggest issue would be finding me one that is for sure Windows 7 happy compatible and easy.
Here are my stringent standards:
- Must be available on newegg.com (or somewhere I live [Tempe, AZ] that is convenient since I am lazy)
- I am only looking for a reputable, time tested, quality item for 30-50 dollars. I don't think I need a killer set and it will be my first sound card other than on board EVER. So the more quality, the more basic, the more simple, the better. I will also be installing this and its drivers myself. So the simpler the better. It is my first rig I built myself (although so far so good, no hiccups)
- Most likely I will be buying a set of these headphones to go with said sound card, so compatible etc. (also willing to take suggestions on anything comparable if someone here does have the know how on comfortable headphones. Mostly computer use for gaming and music with a bit of TV, Hulu, Netflix etc.)
- Here are my Rig specs : Windows 7 64x bit Professional
These components here
Thanks all for the suggestions in advance. If anyone has any other useful information besides just recommending a sound card, go for it. I take criticism/sarcasm very well.
Edit: P.S. I love ASUS. Creative I assume should be great as well yes?
Windows 7 RC - 7100 64bitAMD Athlon(tm) 64 x2 4800+ 2.50Ghz Dual Core4 gig Kingston DDR2XFX Nvidia GeForce GTS 250
- Windows 7 RC - 7100 64bit
- AMD Athlon(tm) 64 x2 4800+ 2.50Ghz Dual Core
- Motherboard
- Hewlett Packard
- 4 gig Kingston DDR2
- Graphics Card(s)
- XFX Nvidia GeForce GTS 250
- Sound Card
- na
- Monitor(s) Displays
- 22" Samsung LCD Syncmaster
- Screen Resolution
- 1680x1050
- Hard Drives
- 300gig Western Digital
- PSU
- BFG Tech 550watt
- Case
- Crap stock Dell
- Cooling
- Side panel open on case, and a box fan blowing in.
- Keyboard
- G15
- Mouse
- G9
- Internet Speed
- Bike Messenger
