Windows 7: Problem with realtek hd audio manager
14 Sep 2011   #11
CS9090
Windows 7 Ultimate 64bit
Well ok so thats it.But can you tell me for some program like Realtek manager? Of this kind that i can use for the same stuff.Thanks a lot for everything
14 Sep 2011   #12
boohbah
have you looked in control panel for the realtek hd audio manager.
go to start menu click control panel and when it opens have a look in hardware and sounds.
14 Sep 2011   #13
Sardonicus
Windows 7 Home Premium 64 bit
Quote   Quote: Originally Posted by CS9090 View Post
No, I don't know of anything, but If someone knows of something, they'll probably post it.
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Realtek HD Audio Manager not there/problem with headset
Hi everybody, since this is the first time using sevenforums I will try to make it readable. So I got sound card with 5.1 speakers on it, and headset sound will work if I put in jack into there where my speakers are, but If I put headset jack elsewhere it won't recognize the device and will do...
New Realtek HD Audio Manager Driver Problem with Microphone
Hello, I'm CrazyKilla So I recently got a new motherboard and because it's a new board, it came with it's own audio drivers, and my old ones were useless (obviously). I installed these new audio drivers and i found that it changed the look (and most likely the software itself) of the Realtek HD...
Realtek Audio HD Manager Equilizer Problem
When one of my friends built this computer for me, the Realtek Audio Manager was working flawlessly. It's been about a year since this computer was first built, and now I'm having troubles with the program. Usually I was able to adjust the sounds using the equalizer and the Room correction, now I...
Realtek HD Audio Manager Problem!
So, I have Realtek HD Audio Manager installed, and the latest drivers. My sound is now working fine, but my microphone isn't even being picked up. I don't know what kind of problem this is, but I was looking for help. My motherboard with on-board sound is a ECS Elitegroup GeForce7050m-m. Thanks for...
Realtek HD Audio Manager and Realtek Audio Driver
Help. I recently did a clean install of Windows 7 64bit (on my HP Vista 32 machine). Life is grand! My problems started when I tried to listen to the microphone input through my speakers. The front microphone inputs did not work so I downlaed the Realtek HD Audio Drivers (recently updated) from...
