Windows 7: Problem with realtek hd audio manager
14 Sep 2011   #1
CS9090
Windows 7 Ultimate 64bit
Hello,everyone i have a problem with realtek hd audio manager.I installed the latest drivers and i dont have the audio manager i am working with Windows 7 Ultimate 64bit as the same i was working on my PC before,but now i am with laptop Acer TravelMate 5760G and i dont have the realtek manager,can someone tell why and how can i fix it because i really need it,or from where i can download it.This is the description of my sound card if it will be helpful for you.
Audio Adapter Conexant Unknown @ Intel Cougar Point PCH - High Definition Audio Controller
Thanks a lot i hope someone will respone or give me an advice that could help me solving this problem.
14 Sep 2011   #2
linnemeyerhere
CS9090,
Welcome to SF. Do you see something on the Realtek site here that is worth trying? Note that they highly recommend using the downloads via the mfgr's. site, have you exhausted the downloads available there as well?
http://www.realtek.com.tw/downloads/...&GetDown=false
http://www.support.acer.com/us/en/pr...x?modelId=3628
14 Sep 2011   #3
CS9090
Thanks for the respone
14 Sep 2011   #4
CS9090
This did not help i downloaded all of these i installed them and nothing again
14 Sep 2011   #5
linnemeyerhere
Bummer, slammed at the moment. I hope others will come and assist, I'll check in later.
14 Sep 2011   #6
CS9090
Ok I think the problem is hiding at the fact that my sound card is Conexant.So I installed the drivers for Conexant but there is no audio manager thats bad ... i tried with the SandBox audio program but i did not like it the way it sounds,its important for me to have a program like this because i listen music trough stereo amplifier and stereo and before i was using this Realtek sound manager and the sound was just perfect now .. its like something is missing and it does not sounds that great like before.Sorry if a i made mistakes but my English is not very good.If you can tell me what other good program i can use instead realtek it will be great.Thank you !
14 Sep 2011   #7
Sardonicus
Windows 7 Home Premium 64 bit
Quote   Quote: Originally Posted by CS9090 View Post
Someone correct me if I'm wrong, but I don't think that the Realtek software/drivers will work with the Conexant audio. Once you install the drivers/software by using Setup, you should see the Conexant device show up in your device manager. If an audio manager is installed when using "Setup" and it doesn't show up in the notification area, you can usually access the application by going to the Conexant program folder. Right click on the application and add it to the quick launch.
You mentioned that you installed the software......whether it be Realtek or Conexant, the driver that is compatible for your system will show up in the device manager. That's the device, you should look for in the program folder to launch the program's audio manager.
14 Sep 2011   #8
Sardonicus
The Conexant software is probably limited in what you can do with it. I wouldn't expect much in terms of sound enhancements, like the Realtek software.
14 Sep 2011   #9
CS9090
Ok thanks about all the info but i have installed it i searched at the folder i installed it i searched in Devices and Printers i did not found it there but i found it in the folder of the downloaded file which i unrared,and when i start it,it just pops out for a second one little black window like the /cmd window and after that it closes and when i click the right button i cant add it to the quick launch there is no option like this can you please tell me how to do it step by step
14 Sep 2011   #10
Sardonicus
There's probably no audio manager included within the software.
The pictures I posted are of the Conexant Audio Message Service.
I doubt there are any advanced sound applications, like with Realtek.
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Realtek HD Audio Manager not there/problem with headset
Hi everybody, since this is the first time using sevenforums I will try to make it readable. So I got sound card with 5.1 speakers on it, and headset sound will work if I put in jack into there where my speakers are, but If I put headset jack elsewhere it won't recognize the device and will do...
New Realtek HD Audio Manager Driver Problem with Microphone
Hello, I'm CrazyKilla So I recently got a new motherboard and because it's a new board, it came with it's own audio drivers, and my old ones were useless (obviously). I installed these new audio drivers and i found that it changed the look (and most likely the software itself) of the Realtek HD...
Realtek Audio HD Manager Equilizer Problem
When one of my friends built this computer for me, the Realtek Audio Manager was working flawlessly. It's been about a year since this computer was first built, and now I'm having troubles with the program. Usually I was able to adjust the sounds using the equalizer and the Room correction, now I...
Realtek HD Audio Manager Problem!
So, I have Realtek HD Audio Manager installed, and the latest drivers. My sound is now working fine, but my microphone isn't even being picked up. I don't know what kind of problem this is, but I was looking for help. My motherboard with on-board sound is a ECS Elitegroup GeForce7050m-m. Thanks for...
Realtek HD Audio Manager and Realtek Audio Driver
Help. I recently did a clean install of Windows 7 64bit (on my HP Vista 32 machine). Life is grand! My problems started when I tried to listen to the microphone input through my speakers. The front microphone inputs did not work so I downlaed the Realtek HD Audio Drivers (recently updated) from...
