Windows 7: I think I blew my jbl desktop speakers,wrong audio settings?
14 Sep 2011   #1
greenwizard
window 7 64b SP1
Stigma Tel high definition audio codec
Current driver: 6.10.5609.0 09/07/2007
My speakers have a strange buzz,& sound kinda wavy.But it seems if I turn it up louder then regularly it goes away.I have not turned them up loud for a month or so.Just started happening today.What kinda setting should I set it too?Theirs alot of different settings,I used one in the middle for awhile.I been fiddling with it & forgot just what one it was.The amp in the speakers is probably going bad.
But I got curious that maybe the bit & hz setting may have caused it.Idk,so thought I would ask.
I think I blew my jbl desktop speakers,wrong audio settings?-m.jpg I think I blew my jbl desktop speakers,wrong audio settings?-mn.jpg I think I blew my jbl desktop speakers,wrong audio settings?-mnb.jpg
15 Sep 2011   #2
fireberd
Whatever settings you make in the PC should have no affect on the speakers. It's still just an analog output and the output level can't go high enough to hurt the speakers. The buzzing is an indication of an internal problem in the speaker system.
Audio 2.1 Speakers+Subwoofer, one speaker not outputting audio
Hi, hope you guys can help/guide me out. So I receive a gift a couple of months ago, but did not have the chance to test it until now. I have a set of audio speakers+sub-woofer, if you take a look at the pics (specially the back.jpg) the speakers are connected through a RCA cable, and where...
Desktop only outputting Left audio. Right does not come out.(Speakers)
Sup! An uncle of mine currently has an old dekstop . He purchased a couple of Technomaster speakers with subwoofer (2.1 Sound System) a couple of weeks ago. He sent the computer to repair at one moment, because the Mobo's LAN card somewhat died (It wasn't detecting the plugged in cable), and was...
CMOS Settings Wrong
Sigh, back for another problem. PC is about 2 months old now. About 2 weeks ago I started receiving an error message while booting up. Very shortly after I boot up the PC, I receive a black screen that points to "CMOS Settings Wrong" "Date/Time not set". Press F1 to run SETUP, Press F2 to...
General Discussion
What's wrong with my connection or settings?
First of all it started when we had a power cut, when I turned my computer back on the internet wasn't working, it constantly said on the bottom right of the screen identifying network, they it wouldsay no internet acces, it would then go on to say that is public or somethig and is a undefined...
Network & Sharing
Speakers Settings
Hey i need a little bit of Help I want to be able to use Stereo mix and my mic at the same time but it doesn't let me change the levels of my mic. Mine Looks Like This http://i53.tinypic.com/21mdk45.jpg But it is meant to look like this. http://i55.tinypic.com/20gy39t.jpg Is there a...
USB Speakers prevent power settings
Hi, my laptop doesn't utilize any of my power settings (dimming, turn off screen, sleep mode, screensaver etc). I noticed that everything works fine if my USB speakers aren't plugged in. I have a pair Altec Lansing XT1. Windows come with drivers dated from 2009 and says everything is working...
Hardware & Devices
