Problem someone help please!
  1. Posts : 22
    Hello.
    I just bought a new SteelSeries Siberia v2 Gaming headset. I tried plugging in just a couple of days ago into my computer. When I did, no input on Skype or my Recording Devices came up. The mic uses standard audio jacks. But, I plugged it into another computer to get it to work, and it worked perfectly. PLEASE HELP!
  2. Posts : 19,383
    Hi Nick and welcome,
    Can you please follow this tutorial to post your full system specifications in order for us to help you quicker:
    System Info - See Your System Specs
    Don't forget Step #5 in the tutorial.
    Regards,
    Golden
  3. Posts : 22
    Alright Golden, I updated my system specs.
  4. Posts : 19,383
    OK. I see you have a Logitech microphone installed. Do you have a Logitech webcam?
    Regards,
    Golden
  5. Posts : 22
    Yes I do, I have been using it as a microphone for the last couple years. I got this headset to use it instead of the webcam microphone.
  6. Posts : 19,383
    OK. Can you find a way to disable the microphone on the webcam? Perhaps a setting in the Logitech software?
    I suspect the Logitech microphone and new headset aren't working well together.
    Regards,
    Golden
  7. Posts : 22
    Umm, would unplugging it do the same thing? Because I don't really need it plugged in anymore anyway.
  8. Posts : 19,383
    Yes it would. But I also recommend uninstalling the Logitech software aswell.
    Regards,
    Golden
  9. Posts : 22
    Alright, I unplugged it and deleted the software, what should I do now?
  10. Posts : 6,879
    Win 7 Ultimate x64
    Is the headset mic (or sound card seeing as that is what it is plugged into) set as the default recording device?
