Windows 7: Problem someone help please!
18 Sep 2011   #1
NickJohnson
Hello.
I just bought a new SteelSeries Siberia v2 Gaming headset. I tried plugging in just a couple of days ago into my computer. When I did, no input on Skype or my Recording Devices came up. The mic uses standard audio jacks. But, I plugged it into another computer to get it to work, and it worked perfectly. PLEASE HELP!
18 Sep 2011   #2
Golden
Microsoft MVP
Windows 7 Ult. x64
Hi Nick and welcome,
Can you please follow this tutorial to post your full system specifications in order for us to help you quicker:
System Info - See Your System Specs
Don't forget Step #5 in the tutorial.
Regards,
Golden
18 Sep 2011   #3
NickJohnson
Alright Golden, I updated my system specs.
18 Sep 2011   #4
Golden
Microsoft MVP
Windows 7 Ult. x64
OK. I see you have a Logitech microphone installed. Do you have a Logitech webcam?
Regards,
Golden
18 Sep 2011   #5
NickJohnson
Yes I do, I have been using it as a microphone for the last couple years. I got this headset to use it instead of the webcam microphone.
18 Sep 2011   #6
Golden
Microsoft MVP
Windows 7 Ult. x64
OK. Can you find a way to disable the microphone on the webcam? Perhaps a setting in the Logitech software?
I suspect the Logitech microphone and new headset aren't working well together.
Regards,
Golden
18 Sep 2011   #7
NickJohnson
Umm, would unplugging it do the same thing? Because I don't really need it plugged in anymore anyway.
18 Sep 2011   #8
Golden
Microsoft MVP
Windows 7 Ult. x64
Yes it would. But I also recommend uninstalling the Logitech software aswell.
Regards,
Golden
18 Sep 2011   #9
NickJohnson
Alright, I unplugged it and deleted the software, what should I do now?
18 Sep 2011   #10
stormy13
Microsoft MVP
Win 7 Ultimate x64
Is the headset mic (or sound card seeing as that is what it is plugged into) set as the default recording device?
Computer is crashing.Problem signature: Problem Event Name: BlueScreen
Hi, My computer, Dell optiplex 760 Windows 7 Professional 32-bit, is crashing. The crashes often happen when i'm playing this game, League of legends, but it also crashes at random points while on a social media or gaming websites. How to fix? Help please.
BSOD Help and Support
Blurry Text problem, EDID and registry editing problem on an AMD card.
EDIT:I have found a solution, using a DVI to HDMI cable on an amd card will fix this problem, this thread can now die, hopefully someone else will find it if they have this problem. Basically, i know what the problem is, but not how to rectify it. My tv (Sceptre X235BV-FHD, a rebranded sony...
Graphic Cards
problem event name startup repair offline - slightly different problem
Hi, Hoping somebody can help with this problem which despite trawling through these very helpful forums & tutorials, I have been unable to resolve. I have tried to include all the information possible although I am relatively new to this field so my terminology is probably not completely...
General Discussion
Laptop Windows 7 Problem/Software/Hardware? Keyboard problem
Okay, right now I'm currently trying to find out whats wrong with a keyboard that is on a laptop, after the computer starts there are some script errors, I don't know exactly what they are but I ran combo fix without safe mode and restarted the scripts went away...and it started working after...
Hardware & Devices
Moving windows/icons down problem!! Move right/left/up - no problem
New system i7 3930K CPU Sabertooth X79 Mortherboard GeForce GTX690 GPU Intel 520 series SSD 32GB RAM Dell U2711 27" Monitor Win 7 Pro
General Discussion
Problem Reports and Solutions - Change Problem Reporting Settings
How to Change "Problem Reporting Settings" in Windows 7 and Windows 8 Sending problem reports to Microsoft helps Windows 7 and Windows 8 to check and identify problems and notify you about any found solutions. This tutorial will show you how to change the Problem Reporting Settings in...
Tutorials
