Microphone way too quiet. Tried two different mics and sound cards.
roper512
8:02 PM
Audio samples at various gains/input levels
My microphone is picking up sound WAY too quiet (even with it at max input level). I can boost up the gain to max (20% for Soundcard, 30% for on-board) and the voice quality it picks up is good, however with the amount of gain used there's hissy noise in the background (to be expected with that much gain).
I have done a lot of searching on google and found many people with the same problem with Windows 7. Some people have had no issues on previous OS's (XP or Vista) and when upgrading to 7 have instantly had mic volume issues.
To troubleshoot this on my own before posting here I have not only tried my headset in my soundcard, but also in the on-board (realtek) inputs. I have also tried a second standalone microphone and had the same exact results. Extremely quiet with no gain. I used the latest drivers for both soundcard and on-board, although I did not have them running at the same time to avoid conflicts. Also, I wanted to try my headset in another machine not using Windows 7 but unfortunately don't have access to one at home or at work.
The only way to get myself audible is to also have hissy noise from cranking up the gain. I find this unacceptable with a good quality headset/mic as I've heard crisp/clear/noiseless dialog on youtube/streaming videos with much lower quality mics.
My guess is there's some conflict going on with my hardware combination and windows 7 that is difficult to pinpoint.. I also reformat fairly often (a couple times a year) and have the same exact problem every time with the most up-to-date drivers.
Something tells me if I built a brand new system with new motherboard, sound card, etc. the problem would rectify itself. I'm going to build a new machine in the next few months anyways, but for now want to be able to do live streaming with noise-free voice. Hopefully someone has some insight here.
Windows 7 64-bit Ultimate (SP1 and all updates installed)
Headset
Sennheiser PC360 G4ME
Soundcard(s)
Creative Labs X-Fi XtremeGamer
Realtek on-board sound
EVGA X58 SLi motherboard
Windows 7 Ultimate x64 w/ SP1Intel i7-9206GB G.Skill2x EVGA GTX580 SLi
Intel i7-920
EVGA x58 SLi
6GB G.Skill
2x EVGA GTX580 SLi
Dell 30"
2560x1600
Intel 80GB X-25 SSD (rev 2)
WD Raptor 300GB
WD Raptor 150GB
WD 500GB
Silverstone OP1000
Silverstone TJ09
Thermalright Ultra 120
Filco Majestouch 2 Tenkeyless w/ Cherry Brown switches
Logitech G400
Comcast 25Mb down, 5Mb up
Are you using both the onboard sound and dedicated sound?
Unless I'm mistaken, you need to disable onboard sound in the BIOS if you want to use the Creative sound card as the default sound settings.
HP Pavilion Elite 495UK
Windows 7 Ultimate SP1 64-Bit
Intel Core i7 870 @ 2.93GHz
MSI 2A9C (CPU1)
HP2310i
460W
HP Elite
Air cooled
Logitech Wireless M180 mouse
2Mb
I specified in my original post that I did not have both enabled simultaneously to avoid conflicts.
When I was running through my sound card (which is how I have been always doing it) I had the on-board audio disabled in the BIOS.
EDIT: Added link to my soundcloud with mic tests at various gains/input levels at top of original post.
Intel i7-920
EVGA x58 SLi
6GB G.Skill
2x EVGA GTX580 SLi
Dell 30"
2560x1600
WD Raptor 300GB
WD Raptor 150GB
WD 500GB
Silverstone OP1000
Silverstone TJ09
Logitech G400
Have you considered using an external microphone amplifier? It could be that the impedance of your microphone is too low to use with your sound card, so you may need to use your sound card in conjunction with a USB microphone amplifer whose impedance matches that of your microphone.
Microphone connected to a computer sound card
MSI 2A9C (CPU1)
HP2310i
460W
HP Elite
Air cooled
2Mb
Hm, interesting.
It just seems like other people get away with setups not really thought out and have good recording volume without noise.
Seavixen - did you listen to my audio samples I linked in my original post? In particular, listen to the ones at 20/30 dB gain.. My fiancee says she can't tell there's hiss with her speakers but I can definitely tell with my headphones. Maybe I'm just being too picky?
I could swear I don't hear this kind of white noise on other peoples podcasts/streams/etc, some of which are using crappy mics.
Intel i7-920
EVGA x58 SLi
6GB G.Skill
2x EVGA GTX580 SLi
Dell 30"
2560x1600
WD Raptor 300GB
WD Raptor 150GB
WD 500GB
Silverstone OP1000
Silverstone TJ09
Logitech G400
win7 ultimate 32bitcore2 Extreme QX6850-OCd to 3.15 GHz4 GBNVidia 8600 GT
SALEON model 2.2b
win7 ultimate 32bit
ASUS P5G41-M LE
NVidia 8600 GT
23" acer
one SATA 250GB partitioned equally in half
one SATA 160GB-internal storage
500W Thermaltake
mini tower
Hm, interesting.
I couldn't detect any noise through my computer speakers, but I did detect very faint white noise through my headphones at the gain settings you mention.
Would I have noticed it if you hadn't mentioned it? I doubt it.
MSI 2A9C (CPU1)
HP2310i
460W
HP Elite
Air cooled
2Mb
Hm, interesting.
Really appreciate the feedback :) Maybe I'm just being too picky afterall...
Intel i7-920
EVGA x58 SLi
6GB G.Skill
2x EVGA GTX580 SLi
Dell 30"
2560x1600
WD Raptor 300GB
WD Raptor 150GB
WD 500GB
Silverstone OP1000
Silverstone TJ09
Logitech G400
You're very welcome.
Too picky? Perhaps, but I am reminded of an old friend who many years ago paid a lot of money for a then state-of-the-art Bang & Olufsen hi-fi system.
When he got it all set up, he couldn't discern any improvement at all and after lengthy investigations discovered he was tone-deaf and no matter how good his system was he could never enjoy the improved sound.
MSI 2A9C (CPU1)
HP2310i
460W
HP Elite
Air cooled
2Mb
Same issue here
Hi all... I have a similar issue with my system, (Win 7 business, Asus on board RealTek HD audio). I did not post samples of my audio, but same complaint. I must go 100% mic gain, and +30 boost to achieve usable audio, but then I get a LOT of hiss, a whole lot more then the previous poster. I've been at this nearly a week and after several microphones, and every combination of settings, still no joy. I have not tried 'Line in', only microphone. Maybe that is next. ~Michael
Windows 7 Business 64 bitIntel i7 9506 gigTwin nVidia cards in SLI
Home brew
Intel i7 950
Asus P6X58D Premium
6 gig
On board audio and Realtek HD drivers
twin Gateway 2400's
1900x1200
More then I need
850 watt thermaltake
CoolerMaster
After market air cooling
El Cheepo
Mickey type mouse
6 Meg from Wave Internet
OS on 1T drive and data on a three drive Raid 5 array. Funky Seagate's not very dependable, will be switching to WD Black drives soon.
Same problem tried multiple mics and reinstalled sound card and still really quite it and it just recently started doing it
Windows 7 Ultimate x64Intel i7
Alienware M17x R3
Intel i7
Seems even I am having this issue. I use the front panel input on the fatal1ty card and with the mic volume knob all the way up and all my settings at 100 I can't get enough volume in my recording. What I do get is clear and good quality but about half the volume I need it to be. I cannot find a +20 boost option which I think is because I am using the front panel input vs the rear panel. The mic is a seismic audio m20 not headset mic. I had the same issue on a headset mic plugged into the back with +20 boost enabled though. The only noticeable difference is that with this mic the noise is gone. So if I could get more volume out of this it would take a bit to get any hissing.
Anyone come up with any other answers? This literally seems to be a 7 problem too.
Win7 64bit UltimateAMD Phenom II X6 1100T Black Edition Thuban 3...CORSAIR DOMINATOR GT 8GB (2 x 4GB) 1866 DDR3XFX HD-697A-CNDC Radeon HD6970 2GB 256-bit
Win7 64bit Ultimate
AMD Phenom II X6 1100T Black Edition Thuban 3.3GHz, 3.7GHz
Gigabyte GA-890FXA-UD5
Creative SoundBlaster X-Fi Platinum Fatal1ty Edition
Dual 25 Inch Hanns-G HZ251
1920x1080 X 2
Corsair 850W Single Rail
Thermaltake V9 BlacX w/ Dual HDD Docking Station
Air lots and lots of air and copper...
Kensington (Low-Profile)
Creative Fatal1ty
15Gbit (15 Down 5 Up)
XIGMATEK HDT-S1284F 120mm HYPRO Bearing CPU Cooler, LG Blu-Ray Burner.
Isn't there an option in control panel where you can just turn down the volume of mic?
64 bit operating system
