Windows 7: No sound with Creative X-FI Elite Pro
21 Sep 2011   #1
seh
Windows 7 Professional 64 bit
So I recently upgraded from windows xp to windows 7 and have been having problems with my sound card. When I select a Playback Device I don't get sound if I choose Creative SB X-fi. However I do get sound if I choose High Definition Audio Device. When I have the Creative SB X-fi selected as a Playback Device and play a song or something with sound, I can see the bars show it's playing sound but I can't hear anything in my headphones.
Also for microphone settings just like Playback Device if I select High Definition Audio Device my microphone works but selecting Creative SB X-fi microphone it doesn't work.
21 Sep 2011   #2
Maguscreed
Windows 7 x64
Am I to understand you have plugged speakers into both the built in audio device and the x-fi card?
Sound coming from the high definition audio device indicates to me that the speakers are plugged into the motherboard not the audio card.
...you should also disable one when using the other.
21 Sep 2011   #3
seh
I have a headset plugged into the back of my computer too where my soundcard is no other sound device is plugged in. I'm talking about right clicking the bottom right corner and going into playback devices and recording devices. Choosing which one is "default" too use. Selecting High Def gives me sound choosing the sound card I get no sound.
06 Oct 2011   #4
seh
Even If I disable the onboard I don't get sound from my soundcard.
07 Oct 2011   #5
seh
sigh from the top
the only way i get sound is enabling my on board sound and selecting High Def Audio. Selecting creative gives me no sound. Also I have to do the same for the microphone enabling on board and selecting HDA for it too work.
I have tried every driver / fix on creative website. Would like to beable to use the $300 GFX card atleast... Let alone creatives fail drivers for w7
07 Oct 2011   #6
stormy13
Microsoft MVP
Win 7 Ultimate x64
Let's start with the basics, you installed the Nvidia chipset drivers?
NVIDIA DRIVERS 15.58 WHQL
Also with the various drivers you have been using System Restore of reloading a clean image after each try? Sound card drivers (and not just Creative's) can and will mess up with repeated installs and uninstalls of drivers.
07 Oct 2011   #7
seh
I'm not sure as I wasn't the person too install everything after changing my OS. How would I check.
No I haven't been using system restore after trying new drivers however the sound never worked to begin with.
Low volume with new sound card(Creative Sound Blast 5.1 VX)
Hello! I got a new sound card today. Installed it, installed the drivers from the CD, plugged in the headphones and it works. But the sound levels are way to low. I raised the volume in all the places I could find, but it's still a bit low. Here's the card: Creative Sound Blaster 5.1 VX...
no sound with Creative SB Live (WDM)
after a power out today i got no sound afterwards :cry: and i tried msconfig device manager and all that i could find on internet please help
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Drivers
Well my Sound Blaster SB0460 X-FI Music Extreme wont work. Win 7 doesn't even see it. When I try to load the Vista drivers it said its not compatible with this operating system. Had the same STUPID problem with Vista until they released Vista specific drivers. Rich
Creative X-fi - no sound after restart
I had noticed that a lot of people first had sound issues with their Creative X-fi soundcards. Most of them sorted it out by running the Creative drivers in Vista compatibility mode, or by installing the support pack released by a member on the Creative support forums. The problem for me is...
Creative SB X-FI Elite Pro Not working
Hello, From the topic title, I have that sound card. I install the latest driver from Creative which is version 2.18.0013. Installs fine, reboots, then the AutoUpdate program comes up to install all the other applications for my device. However, if I try to run like Creative Audio Control...
