It may be somewhat not polite starting my board career with a question, but ultimately searching for a solution on google led me here with a few hits which did not provide any solution for my problem, so I'll try it anyway. (While hoping I don't offend anyone by doing so.
the situation: until recently I only used devices with their own volume control and never even bothered thinking about it, but now I've got a new headset which doesn't have its own volume control.
the problem: The Windows 7 volume control produces suboptimal results. "0" mutes audio, but "1" gives me the same volume on my headphones (as well as speakers as long as I don't use their volume control) as "100" ... and the level always being the same is a problem because it's too loud. (especially on the headphones)
The headphones are connected via their analog jacks and I tried the front audio connector as well as those on the back of the mainboard, which does not change the result. Also setting the volume using the "VIA HD audio deck" produces the same result. (Of course, if programs allow setting the volume it works, but then a single system-sound almost makes me suffer a heart attack.
If anyone has a hint I'd greatly appreciate it.
Regards
