Anyway to get sound per display/monitor?
Cringle
1:11 AM
I have 2 displays, 1 is a TV 3 meters away hooked up to my graphics card via HDMI and the other other is obviously my PC monitor. I was hoping there would be a way to have sound exclusively on the TV while I have seperate audio on my monitor?
Sorry it's a bit hard to explain. Basically I want to play a game on my PC with my headphones on while a film is playing on the TV, but if I try it atm the game shows on my monitor while the film is playing, but the sound of both is coming out of the TV.
Graphics card is a HD6870, using Windows 7 x64.
Thanks.
This is possible as long as the hardware and software allow it
with the set-up you have you probably already have two separate hardware channels to cater for your sound
The HDMI digital output from the Graphics card and an analogue sound card built into the computer, (this may not be present but that would be unusual)
If you set your default to the analogue output then both will come out via the output jacks on the computer to either speakers or headphones.
What you now need to do is go to the [Advanced?] settings of your application that is playing the movie and set this to send to the Digital, (HDMI) output. Not all players will have this functionality, for example PowerDVD does but I do not believe that WMP does.
Hope this helps :)
    Ryzen 9 5950X, 3.8 - 5.2 MHz
    Asus Prime X570-Pro
    64GB [2 x 32GB] DDR4 3200MHz
    2 x 3840 x 2160 @60Hz
    Workstation Case [Matt Black]
    920 MB Down 50 MB Up
    Also run ...
    Nexus 7 Android tablet x2
    Samsung 10.2" tablet
    Wacom Expresskeys Remote
    Loopdeck+ Graphics Controller
    Shuttle Pro v2 Control
    Dell XPS 17 10750H
    Windows 11 Pro x64 Latest RP
    Intel I7 10750H 5.0GHz
    Dell XPS
    32GB [2x16GB] DDR4 2933 MHz
    nVidia GTX1650Ti 4 GB GDDR6
    Stock [Realtek] 4 Speaker
    3840 x 2400
    Stock - Active Fan Control
    Backlit + Various Logitech
    72 MB Down 18MB Up
    Also run ...
    10.2" tablet
    Sony Z3 Android Smartphone
    Shuttle Pro v2 Control Pad
    10TB NAS
An answer I can understand properly :) Gonna try that now, thanks alot for the help.
That worked flawlessly with Media Player Classic, thanks again for your help.
