Windows 7: Playing sound through spdif and speakout out @ the same time
24 Sep 2011   #1
XNemesis
Win 7 64
Is this possible? I'm thinking of adding a soundbar to my 4.0 system and it would use the spdif on the mobo but is it possible to have two default devices running at the same time?
24 Sep 2011   #2
Barman58
Windows 10 Pro x64 x2 Windows 10 Enterprise x64, Ubuntu
It is possible to have two outputs live at the same time, but only if the software supports it, for example most (all?), DJ software packages will allow you to send the output to one device and the monitor (headphone) output to another.
Is anyone playing 5.1 sound with minijacks vs spdif?
If it is working in WMC for you, please tell me your sound card. My MB only has spdif or stereo out from minijacks. I have a free PCI slot but my experience with sound cards has not been good. Can I expect a pci windows 7 sound compatible card to work, like a cheap cm chip card off ebay? ...
Media Center
No sound through SPDIF out (red) Optical.
Hi, I have a Gigabyte GA-Z68X-UD3h-B3 Motherboard, which has a SPDIF out port on it. I followed the instructions by going into the Realtek Audio manager and setting it to "Digital Output (Optical) " and when I test it, no sound comes out, it is hooked up to a Vizio HD Tv, Im using a Nvidia 8800 GT...
What ext video card takes SPDIF audio from ext sound card?
Presently I have to use onboard sound card to have audio through HDMI output from video card. The external sound card installed is Xonar DG and it comes with SPDIF output header to be interfaced with video card. But I do not see no such header on the video card. I wonder what video card has such an...
Graphic Cards
NO sound whatsoever with Realtek AC'97 and SPDIF output
This one has got me pulling my hair out!! I hope you guys can help.. I'm surprised I havent found anyone else in my boat out there! I have a little Shuttle G2 6100H, also known as the SB61G2v3.It has the FB61 v3 motherboard made by Shuttle themselves and an onboard Intel Springdale 865...
Drivers
No sound from SPDIF Xonar DS output to TV with Windows 7
Ok before I had Windows XP...have a Xonar DS Audio card with a SPDIF output going to my Nvidia 9500GT Video card...the video card is connected to my Yamaha V-867 Reciever via HDMI and then of course the reciever to the TV via HDMI. So with XP it worked great. Had the video card set via the...
No sound through SPDIF on Auzentec X-Plosion 7.1
Help! I've just upgraded from Vista to 7 home premium and found the soundcard digital output through the SPDIF optical connector is not working. I'm using latest drivers from Auzentec's website. At the moment I've got a nice HTPC with no sound! OK, not quite true - the jack outputs are...
