Windows 7: No Audio Output Device is installed.
28 Sep 2011   #11
sian21
Windows 7 Ultimate 32-bit
Help me please
28 Sep 2011   #12
Sardonicus
Windows 7 Home Premium 64 bit
Use the following tutorial to show hidden devices and enable them.
Audio Device - Enable Hidden Devices - Vista Forums
28 Sep 2011   #13
sian21
doesn't work also cant enabled the Streo Mix in the Recording tab
28 Sep 2011   #14
Sardonicus
Do a system restore, if possible, to the restore point prior to your use of the updating software.
28 Sep 2011   #15
Big Tom
Windows 7 Professional x64
^^^ what he said. that info would help alot. just because you "upgraded" doesnt mean the new one is compatible. my old sound card worked fine in windows 7 x64 until i enabled more than 4gb of ram. i went to staples and bought a cheap $20 win 7 compatible card and now problem solved. also my computer did say "no audio output device installed" just like yours. maybe yours just wont take sound from the internet. a lot of times incompatible things may still "work" but the output may not be what was expected
28 Sep 2011   #16
sian21
Quote   Quote: Originally Posted by p5bdkw View Post
Cant do a system restore all my restore points was deleted.
28 Sep 2011   #17
Sardonicus
Please post a pic of your Device Manager with the Sound, video and geme controller tab open.
28 Sep 2011   #18
sian21
Here ya go.
28 Sep 2011   #19
Big Tom
realtek high definition audio is not an actual sound card. it has something to do with onboard audio systems on a lot of machines. if you have changed your card to a different one, then you shouldn't be using that for your sound. you should have another device show up in the control panel. what card did you upgrade to? this will help us a lot
28 Sep 2011   #20
Sardonicus
Also post a pic of your playback devices.
No Audio Output Device is Installed
I believe this is an issue regarding an update. I had this issue before and did a system restore to back before I had installed a certain program, and the issue went away. Now however, I do not have a restore point that will go far enough back. I started up my computer today and I was hit...
Drivers
This is my wife's sony vaio, and she has had this problem with no sound on her laptop, when checking the volume control it says no audio output device installed. In device manager it says that she has Intel display audio. I need major help here please.
No AUDIO OUTPUT DEVICE IS INSTALLED
No AUDIO OUTPUT DEVICE IS INSTALLED, this is the message l got on sound icone since l installed windows 7 l have downloaded it several time the latest one it shows on control panel but not on device manager, l guess this is not really installed but l keep installing it and restat the laptop...
No audio output device installed
I bought a generic computer. It had windows vista installed and it used to display a message that No audio output device is installed . I recently installed windows 7 home premium 32 bit on it but it still says the same thing. I went to properties of it and found following error message.This device...
No audio output device installed...Tried everything, need some help.
All fixed...Hardware issue. Stripped it down and rebuilt it. Booted up and installed the drivers....woohoo I have sound again...lol Hi, I have had this problem now for a couple of months. What I have tried: Reinstall windows 7 Update bios Install the realtek high definition audio...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
