No Audio Output Device is installed.
Page 3 of 4 FirstFirst 1234 LastLast
  1. Posts : 29
    Windows 7 Ultimate 32-bit
       #21
    p5bdkw said:
    Also post a pic of your playback devices.
    Is this what youre talkin about?
  2. Posts : 150
    Windows 7 Professional x64
       #22
    a new device should show up in playback devices and also in the control panel
  3. Posts : 29
       #23
    Big Tom said:
    realtek high definition audio is not an actual sound card. it has something to do with onboard audio systems on a lot of machines. if you have changed your card to a different one, then you shouldn't be using that for your sound. you should have another device show up in the control panel. what card did you upgrade to? this will help us a lot
    Idk what you're talkin about (cos im not good at pc) i only did was one of my program changed my sound card into Realtek and the sound was gone.
  4. Posts : 1,996
    Windows 7 Home Premium 64 bit
       #24
    Yes.
    Unplug your speaker jack and plug it back in to see if the jack detection pop-up appears.
    If it does, click OK.
    Do you have sound?
  5. Posts : 29
       #25
    Still there's no sound but the realtek HD audio manager pop up that i just plugged a device in a jack.
  6. Posts : 1,996
       #26
    Restart your PC.
    Do you have sound?
  7. Posts : 29
       #27
    no sound.
  8. Posts : 1,996
       #28
    I've noticed that your pic doesn't have the speaker increment bars as in my pic below.
    Try re-installing the latest Realtek software over what's on your computer.
    It will ask if you want to modify/repair or remove the software.
    Choose remove. Restart your computer. Windows will probably install the generic driver.
    Install the Realtek software. Restart your computer.
  9. Posts : 29
       #29
    still the same
  10. Posts : 1,996
       #30
    sian21 said:
    still the same
    Unfortunately, you may have to do a clean install to fix it.
