normal speakers sound but low in headphones
  1. Posts : 9
    Windows 7 Ultimate 32 bit
    hi everybody :)
    I recently bought Acer Aspire 4738 i5 (running 7 ultimate 32bit) and I love it so far. however there's a problem with sound when I plug in the headphone.
    when I play it through the build-in speakers the sound is great and actually loud , I've tried another headphones (bought three already :/ ) and still the same thing.
    updated the drive, checked the volume to max, tried about everything i could find but nothing seems to work.
    I'm starting to think this is an OS issue,
    Plz help, headphones are something I can't live without !
  2. whs
    Check in the "Levels" tab in the Properties of the headphones.
  3. Posts : 9
    I can only see speakers and its set to max
  4. whs
    Are your headphones plugged in?
  5. Posts : 9
    yes they are
  6. whs
    Something is wrong. Try this - see picture.
    Attached Thumbnails Attached Thumbnails normal speakers sound but low in headphones-2011-10-01_2209.png
  7. Posts : 9
    its already set on show but I redid it anyway nothing appeared Whs
  8. whs
    I can only suspect a bad contact. As you can see, mine shows up properly. Maybe the 3.5mm plug or port is bad and that is the root cause of the problem. Try turning and jiggling it a bit - no force though.
  9. Posts : 9
    no still nothing I also restart and tried but didn't work
  10. whs
    I would love to help you find the problem, but I am out of ideas. Let it rest for a bit. Maybe another member knows better. Wgat really disturbs me is that the headphones do not show up in Playback Devices.
