normal speakers sound but low in headphones
lil mike
11:57 PM
hi everybody :)
I recently bought Acer Aspire 4738 i5 (running 7 ultimate 32bit) and I love it so far. however there's a problem with sound when I plug in the headphone.
when I play it through the build-in speakers the sound is great and actually loud , I've tried another headphones (bought three already :/ ) and still the same thing.
updated the drive, checked the volume to max, tried about everything i could find but nothing seems to work.
I'm starting to think this is an OS issue,
Plz help, headphones are something I can't live without :cry: !
Windows 7 Ultimate 32 bit
Check in the "Levels" tab in the Properties of the headphones.
I can only see speakers and its set to max
Are your headphones plugged in?
yes they are
Something is wrong. Try this - see picture.
its already set on show but I redid it anyway nothing appeared Whs
I can only suspect a bad contact. As you can see, mine shows up properly. Maybe the 3.5mm plug or port is bad and that is the root cause of the problem. Try turning and jiggling it a bit - no force though.
no still nothing I also restart and tried but didn't work
I would love to help you find the problem, but I am out of ideas. Let it rest for a bit. Maybe another member knows better. Wgat really disturbs me is that the headphones do not show up in Playback Devices.
thank you Whs for your help, you did what you could +rep :)
hopefully someone could help out there..
Miscellaneous - clutching at straws:
1) Can you bring up the Realtek Audio Manager and see what level is set there.
2) Do your speakers also have a headphone socket. If so is the result the same as directly connecting headphones.
3) What type of headphones are you using (eg. impedance?)
Windows 7x64 Home Premium SP1Intel i7 2600kG.Skill Ripjaws (DDR3-1600) 2x4GBNvidia GeForce GTS 450; Intel HD Graphics 300...
Own build
Intel i7 2600k
ASUS P8Z68 Deluxe
Seasonic M12II 520W
Lian Li Lancool PC-K60
Logitech MK520 (wireless)
Logitech MK520
6-7 Mbps
FireFox
Audio: Logitech Z523 2.1
1-
2- no its a build-n speakers (notebook)
3- a regular 32 ohms
looks like I'm alone at this :(
ok do u think its an OS issue, like if I format and reinstall will it solve this ?
I didn't get back because I'm stumped.
Maybe check the specs on the notebook and make sure it isn't just a "line out" connection intended to be connected to amplified speakers.
I would have thought a notebook should be able to drive a pair of headphones.
Before you reinstall the whole OS try running a lightweight live linux CD like Puppy linux. If you have the same sound problem then it's probably hardware related.
Own build
Intel i7 2600k
ASUS P8Z68 Deluxe
Seasonic M12II 520W
Logitech MK520
6-7 Mbps
FireFox
Now we are two that are stumped. I also think it is most likely something in the port or a wire is dangling.
thx guys I don't wanna put any pressure on u
I'll try ur suggestions plus couple more and get back to you so this would be a reference to whoever needs it.
