Solved Front panel audio connections to motherboard Not Working!
cynet
3:18 PM
Building a new rig, but for some reason there is no sound when I boot the machine up, the sound always come's from the front panel audio connections to motherboard and case Hd audio or AC97 wires which are both compatible on my motherboard.
The gaming case is a Antec 900, it all seems wired up correctly, just puzzled in why I can't here the beep sound when it boots up, any one got any suggestions please.
Win 7 64 bit
Win 7 64 bit
The "Beep" sound that I think you're referring to is the post beep.
That does not come from the front panel audio connections.
That comes from the Motherboard speaker and is a separate connection.
If you want to hear the post beep, get a hold of a motherboard speaker. It's a little tiny thing that plugs into 2 of the pins on the bottom right hand corner of your Motherboard.
The function of this speaker is only for those little beeps and does nothing else of value. But it can be handy if you have a hardware failure or something like that. Each motherboard has it's own little morse code of beeps depending on what is going on. A single beep means everything is cool and it kicks off into the boot sequence.
Windows 7 Professional 64 Bit Service Pack 1Intel i7-2600K OC to 3.8GhzCorsair Vengence 16GB (X4 4GB)X2 EVGA GTX570 SLI
Asus TUF Sabertooth P67
X2 EVGA GTX570 SLI
Creative Soundblaster X-FI TI
Dual HP 2311 LED Displays
1920X1080 single / 3840X1080 desktop
Crucial Force 3 SSD 120GB 6Gb/s ( OS Drive )
WD Caviar Black 2 TB 6 Gb/s (Data drive)
Kingwin Mach 1 1000w Modular 80+ Bronze
AZZA solano 1000
Zalmen 700 LED CPU, X2 240mm case fans , X3 120mm case fans
Razer Black Widow Mechanical
Razer Mamba
26.7 mb/s Down / 7.39 Up
The "Beep" sound that I think you're referring is the post beep.
O'k being a half novice I'm wondering where the motherboard speaker wire goes too from the pins you speak off, I have fitted in a Gigabyte X58A-UD3R REV 2.0, thank you for the quick reply and help.
Win 7 64 bit
Win 7 64 bit
A motherboard speaker is it's own little thing that sometimes ships with the motherboard.. sometimes not. If you look at the connections down where you plugged in your wires for the HDD light and Power switch, you will see a couple connections there listed as " Speaker"
Get one of these and plug it in on those pins.
They are dirt cheap. Got a dollar?
X2 EVGA GTX570 SLI
AZZA solano 1000
Razer Mamba
Thank you buddy, I really appreciate your time and help, all the best :)
Win 7 64 bit
Win 7 64 bit
Reputation is always a welcome thanks!
X2 EVGA GTX570 SLI
AZZA solano 1000
Razer Mamba
