realtek sound pbm
hey plz help me... headphones are nt cnncted to my pc and its cnncted to other pc... wts d pbm in my pc dudes.....?
and once again the mike is working yar....
Please describe the problem like you can speak English and give us some more info about these headphones...
speedgamer01 If i understand well...the above is.....
"Hey please help me...headphones are not connected to my pc and its connected to other pc what is the problem in my pc dudes.....?
and once again mike is working yeah...."
I believe the specific headphones are not working in OP pc but they work in his friend pc.
I speak txt!
Open the Realtek sound manager to see if it detects your headphones, check the volume controls there.
If not, try another headphone port - there should be one front and back.
Next try uninstalling the driver in Device Manager, restart the computer to let it reinstall driver.
Next write down the exact make/model Realtek sound device, then uninstall Realtek Sound driver software at Control Panel>Programs and Features. Now check repeatedly for Windows Updates to see if it has a specific driver it wants you to use, install it.
If Windows Update does not deliver a driver within 24 hours, import the driver from the Support Downloads webpage for your model computer or sound device.
explain you problem properly.. then we can solve it out for you...
