Audio devices undetected. Headphones or Speakers give no sound
  1. Posts : 6
    Windows 7 Premium
    I recently went into my computer to install a Corsair H80 Water pump for the GPU. Anyhow, after i connected all the cables and turned on the computer again i did not have any sound. Even though im not an expert with computers, i'm pretty sure all the cables are connected right (but there is always a possibility i screwed up there).
    I do have sound devices, that is not the issue. After the first pc boot i had the Realtek digital output (realtek high definition audio) as the sound device. I went into the control panel and pressed sound. The previous audio device (that i had and was working) was there, but stated as "Not plugged in".
    So, my computer does not detect or react as i connect any headsets nor speakers. I also checked the audio in the mixer to see that it "plays sound" which i can confirm.
    I have searched the web for people with the same issues and tried a few "solutions" but none of them worked for me.
    They were:
    1. Uninstall and reinstalling the drivers
    2. Making sure i got the latest versions of the drivers
    3. Turning on the front jack panel in the Realtek HD Audio Manager, which resulted with the speakers apparing to be connected and works according to the computer but still no sound.
    4. Tried different speakers and headphones.
    So my question is, do you guys have any idea what to do? I have been sitting on this problem for quite a while now.
    After trying several things im starting to believe it might be me who failed at connecting the computer. But if so i have no idea how to fix it, as it does not matter if i connect the audio cable instead of the HD audio cable or if i leave them unconnected.
    Anyhow: My os is Windows 7 Ultimate
    I got an Intel motherbord DX58SO
    and my sound device/card is Realtek high definition audio? :S
    Good luck solving this puzzle because it's sure giving me an headache.
    Reply if you got any information or need some more information from me?
    (I also recently deleted my hard drive and reinstalled windows, if that matters)
    The first thing to do, since you had it apart to install the water cooler, is to double (or triple) check all the internal cabling between the motherboard and the front panel connections. Second is to doublecheck the connections from your speaker system to the PC.
    What is the status of the Realtek in the Device Manager? Does it show an error or does it show "working correctly"?
    Are your "Speakers" set as the Default audio playback device in the Control Panel/Hardware and Sound and finally the Sound Panel?
    Has audio worked since reinstalling? Did you reinstall the Intel motherboard chipset drivers when your reinstalled? The motherboard chipset drivers are critical and many devices either will not work or not work correctly without the chipset drivers.
    I know these are a lot of questions but a place to start.
  3. Posts : 6
    Windows 7 Premium
    I will try to replug the whole computer once more, but from my perspective the cables seems to be in place at the moment.
    But to answear your questions:
    The status of the realtek in the device manager is perfect. It says everything is working and there is no error.
    Audio have not worked after reinstalling, but nor did it work a couple of the days before ( which was one of the reasons i reinstalled to check if it helped).
    I cannot set my speakers as default audio playback device as it says they are not connected.
    But unless you have any other ideas i will try to replugg it as soon as i get time and post the results here.
  4. Posts : 8,135
    Installing the Intel motherboard chipset drivers, as I suggested, is another thing to do, whether you have or haven't installed them. The chipset drivers are key to a successful install and devices on the motherboard working or working properly.
    I realize you checked the cabling. Murphy's Law always applies and one may have been overlooked or not connected properly. I used to manage a network and hardware help desk, the double or triple checking fixed a lot of problems.
  5. Posts : 6
    Windows 7 Premium
    Sorry for being so slow.
    But anyhow, now i have reconnected the computer twice. With no result.
    Also i went on a raid from store to store looking for a Convertor
    but it seems like this dont exist? or i just described it wrong...
    Anyhow would this be a temporary solution to my problem and work if it was so that my internal sound card is broken
  6. Posts : 1,218
    you should try a CD boot to Linux and see if you have sound from that, if you do then the card is definitely not broken, then it is a windows issue.
  7. Posts : 6
    Windows 7 Premium
    Tried Linux, sound still not working. So i suppose the sound card is broken, thats the only reasonbly explanation is it not?
    Also would a "TerraTec SoundSystem Aureon Dual USB" give me sound even thou my card is broken, considering it is USB and works as a eksternal soundcard?
  8. Posts : 477
    Windows 7 Ultimate 32 Bit, Windows Developer Preview, Linux Mint 9 Gnome 32 Bit
    Have you checked the BIOS to see if your sound device is disabled or not?
  9. Posts : 6
    Windows 7 Premium
    Yes, i've been into bios multiple times where i have disabled on-board audo and then re-enabled it after seeing it makes no effect. I've tried to disable hd audio, and i also updated my bios to the latest version to see if this would increase my options regarding audio, but no help there.
    I'm just assuming my sound is dead, and i have to buy a new card. Does'nt that sound right? and the reason is most likely because i didnt wear one of those bands making me, forgot the word but so that i dont send electric circuits?
  10. Posts : 477
    How old is your computer? Is your motherboard considerably old or maybe not that old at all? Have you looked at the aspect of cleaning the motherboard components, maybe the dust is killing the sound or what? Maybe a computer technician could first look into this problem before you buy a new sound card?
