5.1 Sound doesnt work at Realtek High Definition Audio Device
Page 2 of 2 FirstFirst 12
  1. Posts : 49
    Windows 7 Ultimate 64-bit SP1
    Well Laptop is Dell XPS M1530 Speakers are an old model 5.1 Logitech ... (Dont remember what model :P)
    But i will tell that on my other Computer with Windows xp installed and the driver(Cmedia) that came with the PC for audio, there i just connected the 5.1 speakers and could adjust the level of rear or front speakers throught the Panel of the Cmedia Programm...
  2. Posts : 11,424
       #12
    Well how the system could distinguish the rears from the mains with one stereo plug would be of interest to me if this plug can sort which are which I'll stand corrected.
    Understanding Computer Audio Part III - Interconnects
  3. Posts : 6,879
    Win 7 Ultimate x64
    Big difference between a desktop that has the necessary jacks for 5.1 sound and a laptop that only has a single stereo jack. In the case of your laptop it may have to audio out jacks on the front edge, but they are both stereo jacks for use with two sets of headphones,
    Now with that said I have no idea if it is even possible to set them in 5.1 configuration as it would also include having to re-assign the mic jack for use as either the rear or center/sub out. Only way to find that out is to check whatever control panel the driver installed if any, or contact Dell and ask if it is even possible.
  4. Posts : 49
       #14
    Ok understand ... So my "dreams" of listening 5.1 on my laptop dont became true :P :P
    Thanks everybody for your answers!
  5. Posts : 11,424
       #15
    Well hold up there......we are saying you can't get 5 or 7 discrete channels a out of a single stereo plug. But this little add on will get you in business !
    Sabrent USB-SND8 8-Channel USB 2.0 External 7.1 Sound Box at TigerDirect
  6. Posts : 49
       #16
    yes that is good.. but i see there is a lot of connections plugs ... and i have only three the orange black and green..
  7. Posts : 11,424
       #17
    That's because it's 7.1 ready but works great as well with 5.1 channels. Leave your speakers plugged in and then just attach the usb to the laptop and disconnect to travel.
