Windows 7: sound is too low problem
16 Oct 2011   #1
lebdorz
7 ultimate x86
Hello
I am suffering from a too low sound in my headset .. it's new and tried on other windows and it's great
it was really fine when I was using Xp Sp3
but since I installed 7 Ultimate..the sound became 50% less
I raised all the available sounds and still the same
Can u Help plz ?
PS: I went to My computer - Manage - Device Manager - and it's all quite good and drivers seem to be installed
Thanks in advance
16 Oct 2011   #2
debugged
With your media player running, right click on the speaker icon in notification area (bottm right of taskbar) and select "Open volume mixer" and adjust volume there. If the icon isn't showing you can Run > sndvol to open volume mixer.
16 Oct 2011   #3
lebdorz
7 ultimate x86
Quote   Quote: Originally Posted by debugged View Post
thx but all of them are set to be high and still the sound isn't enough as it was on XP
16 Oct 2011   #4
debugged
Next, try this: Control panel > Sound > Communications tab: tick "Do nothing".
Also, back in Volume mixer, you might see if it helps to mute System sounds.
I'm assuming you did this one already but if not: In Sound dialog, select your output device, click on Properties, and Levels tab and increase sound there. Also play with the Enhancements tab - try disabling all sound effects; if no luck, then try what "Loudness equalization" does for you.
Then for headphones, try configuring for stereo: In Sound dialog, select output, then click on Configure, select Stereo. Then click next and see what happens if you select Full range speakers, then Next and Finish. I'm not using headphones, so I can't say. But this last move makes a noticeable difference when playing through quality desktop or floorstanding speakers.
16 Oct 2011   #5
serpentracer
windows 7 ultimate 64 bit
usually headphone jacks don't have high volume levels. (helps prevent you from going def)
16 Oct 2011   #6
lebdorz
7 ultimate x86
debugged..thanks buddy
Ytied them all and still the same
anyway...Windows 7 sounds and photo viewer really sux ..full of bugs and many more
16 Oct 2011   #7
Vertex
Windows 7 Ultimate 32 Bit, Windows Developer Preview, Linux Mint 9 Gnome 32 Bit
What media player do you use? Do you use Windows Media Player 12? By default, its volume levels are not set to maximum on Windows Media Player 12 so please check that. If this is not the problem, I assume this might be a problem with the sound driver even though its listed as OK on the Device Manager. You may also check hardware driver updates from Windows Update which is on the Control Panel.
I had some sound problems too with Windows 7, my front panel jacks has no sound output and my rear panels have weaker sound output than expected that was until I installed a compatible driver from Realtek. The front panel jacks were working again. And the rear panel jacks went better too. My advise would be to plug your headset on another jack and see if it works. Depending if your sound adapter supports it, you might have to install a driver from Realtek. Check this link:
Latest Realtek HD Audio Driver Version
Then after you're done with that, follow what I did to configure Realtek's settings on a screenshot on the link below:
http://www.sevenforums.com/attachmen...ll-egegewg.png
16 Oct 2011   #8
debugged
Quote   Quote: Originally Posted by lebdorz View Post
...still the same...
Bummer, but now you've done all the normal things. Vertex might be on to something abnormal about the jacks so let us know if you sort this out. Look at this funny comment from another forum:
"My computer suddenly got this low sound -problem and I tried literally everything to bring the sound levels back to normal. Then I noticed that (for some very mystic and strange reason) the sound levels were normal if I plugged my speakers in the front jack of the computer and something in the rear jack. Now I keep broken headphones in the rear jack to keep the problem away. Strange, but it works for me."
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound problem perrsists even after new sound card
As some of you might remember, a few weeks ago I had a problem with sound after I built a new PC and kept my old Win 7 installation using sysprep: http://www.sevenforums.com/sound-audio/280175-onboard-sound-issue-new-pc-build-2.html#post2308990. The problem was that the volume levels were off, and...
Sound problem
Hi all, I had this problem with my laptop sound randomly disappears and it comes back after a while like 15 min or so.I have Realtek HD Audio Driver installed.Is it problem with my driver? Can anyone help me with this? i am despreate !!!
Sound problem - need to 'scan for hardware changes' to get sound
Hi everybody I have a fairly strange problem with my Laptop. It came originally with Vista and a while ago I updated to Windows 7 32bit Home Premium. Since then I don't have any sound after booting the Laptop. By chance I found out that when I go into the device manager, right click on the sound...
Hardware & Devices
Windows Media Player Problem - Sound/skipping problem.
Oh look, another windows media player problem, lol. Well, it's something really weird, at first i thought it was just my computer being all slow or the file was messed up, No matter what movie or format i play it makes this weird screeching noise. It also lags pretty bad. I tried the scans, i did...
Music, Pictures & Video
sound problem
Hello, I have a sound problem on my HP Pavillon desktop (windows 7). Everytime, after some hours of use, I hear sound clicks&pops. I restart, and the problem is back after some hours. When sound clicks&pops occurs, I see abnormal CPU usage in task manager. Like going back and forth...
