Built-in microphone not working.
Cloa
7:35 AM
Hello,
I have installed Windows 7 Professional from Home Basic in my laptop about 3 months ago. The problem is, I cannot record any sound from my internal microphone after the installation. I think I have installed all the right drivers in my notebook and I have searched for troubleshooting my microphone. But the result is still the same. I only hear a hissing sound whenever I record a video.
Please help.
Windows 7 Professional x32
Can you add your hardware specs please? Laptop make and model, soundcard details etc.
Windows 7 Ultimate x64Intel Core 2 Duo E840016GB OCZ GoldNVidia 9600GT 1024MB
Gigabyte GA-EP45-UD3P
16GB OCZ Gold
Focusrite Saffire Pro 40
2x Samsung 2433BW
1920 x 1200
Corsair Force 3 120GB SSD
BeQuiet Straightpower 600W White
Lian Li Rack
Arctic Freezer Pro
MS Wireless Keyboard 3000
MS Wireless Mouse 5000
8MB
Tell me what more do you need sir. I can't fix my laptop microphone problem so please help me. Thanks.
do you know what kind of motherboard you have? if so, look up its website, support>drivers and download all its drivers for your particular board (be sure to get the bits and versions right). Do you have an internal microphone because you own a laptop?
Microsoft Windows 8.1 Pro 64-bitIntel(R) Core(TM) i3-4130 CPU @ 3.40GHz8.00 GBNone
Custom Asus Build
B85M-E
8.00 GB
None
Asus 23.6" Monitor
INTEL SSDSC2BW180A4
Samsung SSD 840 PRO Series
Seasonic S12II-380Bronze
Lian Li
Fan, Passive
Logitech K120
Microsoft Touch Mouse
Eset Endpoint
Internet Explorer, Chrome
Thank you for your reply DustSailor. I downloaded all of the necessary drivers my laptop needed. And yes, my laptop has an internal mic that won't work. Any suggestions how can I fix this?
okay, you'll need to download the drivers/software for the camara (aren't they connected, mic and camara?)
is it only a particular application that you can't record your voice on, or does everything not work?
type, "Set up a microphone" into Windows search and you could try your hand at the wizard that pops up.
Look up your microphone and see if there are any settings you can play with. Here is mine (mic and camara)
Go into your sound and check recording devices and see if the bar moves when you make noise:
Let me know how it goes and I'll help you further depending on what you tell me
Custom Asus Build
B85M-E
8.00 GB
None
Asus 23.6" Monitor
INTEL SSDSC2BW180A4
Lian Li
Fan, Passive
Logitech K120
Eset Endpoint
