Windows 7: Sound -> Recording -> Stereo Mix -> Listen to this device, causes echo
21 Oct 2011   #1
Windows 7 Enterprise 64 bit
Hi All,
I am trying to record a video with sound using Windows 7 Enterprise (Windows version 6.1 build 7600).
I have been told that, in order to capture the audio, I need to goto Sound -> Recording -> Stereo Mix -> Listen, and temporarily select "Listen to this device".
However, when I do this the sound is echoing, and the echo is being recorded in the video?
Please can you advise how I can remove the echoing. Or is there a better way to record with sound?
Thank you for your time and help,
Best regards,
James
 Sound -> Recording -> Stereo Mix -> Listen to this device, causes echo problems?
Similar help and support threads for: Sound -> Recording -> Stereo Mix -> Listen to this device, causes echo
The Stereo Mix on my computer isn't recording sound? Sound & Audio
Line-in recording device gone. Want to record from my external stereo. Sound & Audio
Stereo Mix Echo + White Noise When Recording Fix! Sound & Audio
[Recording] Stereo Mix Available, Sound Recording Not Sound & Audio
Stereo Mix not recording any sound Sound & Audio
