Windows 7: Device working but sound doesn't come out Digital Audio S/PDIF
29 Oct 2011   #1
Windows 7 Home 32bit
I have a problem with audio, after upgrading to windows 7 home 32 bit, I installed all the drivers that are neccessary for windows 7. My audio device is High Definition audio device but the only device I can see is Digital audio S/PDIF. Other devices that may be disabled don't appear. I installed all of the Realtek drivers for on board audio device. and I tried installing several others aswell but with no luck. I tried all of the solutions that I was able to find online and nothing works. My microphone works cause I tested it with a friend on skype which gives me the reason to believe that the actual device works.
When I install Realtek driver, it won't show up in my device manager, or sound (only Digital audio), when I run troubleshoot compatibility on any Realtek drivers it detects that the driver is not compatible with my system. I uninstalled my driver that automatically installs on every boot and then I disabled the automatic driver install, and I disabled automatic updates to prevent auto install of the driver that clearly doesn't work. but on the next boot the driver automatically installs again.
The audio doesn't work when I plug my speakers in any port and I dont have front jack on this PC.
I have Pentium D dual core 3.0ghz 4gb Ram and my hardware ID of HD audio device is HDAUDIO\FUNC_01&VEN_11D4&DEV_1986&SUBSYS_1043818F&REV_1005
HDAUDIO\FUNC_01&VEN_11D4&DEV_1986&SUBSYS_1043818F.
I totally ran out of ideas, it's 4 days that I'm trying to find a solution to the problem. Any help is appreciated.
29 Oct 2011   #2
Microsoft MVP
Win 7 Ultimate x64
Alen88 weelcome to the Seven Forums.
Your motherboard doesn't have Realtek audio, it has the ADI 1986 based on the DevID,
PCI Vendor and Device Lists
Knowing the make and model of the motherboard would help in finding if there are Windows 7 drivers for it, but I have a feeling there won't be. If you're feeling adventurous you can try the driver from here,
ADI SoundMAX 86/88/A/B/89,Xonar [6585/6600/6605][04-03-2010] • nForcersHQ.com
and follow the 2 steps on how to add the DevID from yours so that it will install.
29 Oct 2011   #3
Thank you so much. I installed ADI soundmax and followed everything and it works.
Thanks for your time mate I very much appreciate it
29 Oct 2011   #4
Microsoft MVP
Win 7 Ultimate x64
You're welcome.
04 Feb 2013   #5
Windows 7 Ultima x32bit
hey stormy can u help me on finding my driver on nForcersHQ
my ven id:1106 , and dev id:0397
i've registered to that site and been looking for my driver but nothing found.. Please..
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
