Windows 7: is it possible? Keeping sound on in sleep mode?
02 Nov 2011   #1
Rainstalk59
Windows 7 enterprise
Hello i have a windows 7 pc with the a sound card capable of listening to line in sound. i currently have my att uverse box connected to my pc and my pc connected to my stereo system this way i can play my sound through both systems. While i am sure that there a is hardware specifically designed for channeling sound in this way i'm lazy and don't feel like buying them. My only problem is that i have to keep my pc on at all times for the tv sound to remain on. I was wondering if theres a way to keep audio on in sleep mode/away mode that way my computer would remain in a low power state and i would still be able to hear audio on tv.
ATT BOX ==audio== PC line in====PC line out====Stereo
btw the reason i did this is because i don't have a tv and have two monitors so one monitor is on a dvi switch.
02 Nov 2011   #2
Corazon
Windows 7 Professional SP1 32-bit
No, that's not possible. The audio doesn't just simply go in and back out - it's actually put through the chip on the soundcard, i.e. digitized, mixed with any other sounds, then turned back into an analog signal before being put out.
Obviously, none of that happens when the system is asleep.
You might simply get an Y-cable which takes the outputs from your PC and the U-Verse box and combines them into one signal for your stereo system. That way either sound source can be heard independently from the other one (but also together).
Don't be lazy.
My PC has no sound after sleep mode.
Upon waking my PC from sleep mode the sound will not work. Any help will be greatly appreciated.
Windows 7 Sound gone after Sleep mode Help
Hello dear friends, There is a weird sound issue: When I put my Pc on sleep mode and after wake-up the sound is gone and videos are lagging (1frame per 2 seconds).In device manager, it says all audio drivers are working properly, only restarting the PC fix the problem. But I definitely need...
No sound after computer wakes up from sleep mode - Win7
Hello, I am using the realtek onboard sound that came with my Gigabyte MB. Sometimes when I wake the computer up, it says that I disconnected the sound. However the speakers are still connected. Even if I plug in a set of headphones that I know work, the system will not recognize them. If I...
No sound after sleep mode
Hello, I am having problems with my onboard sound not working after my computer wakes up from sleep. I need to restart the computer to get any sound in the speakers again. Note that this is regarding my motherboard in which I have my speakers plugged in. My headset works fine after sleep,...
Hello, I have recently installed windows 7 on my laptop and i am having the same problem i had with the beta. Upon start up, the audio works fine but after i close my laptop and it goes into sleep mode, when i come back and open it the audio no longer works. I cant hear anything. I dont know...
sleep mode causes sound issues
Greetings to all of you, I've used Windows 7 RC for 3 days now, and quite love it actually. But, from the moment I installed it, I had a weird issue. Whenever my computer (laptop/notebook (whatever you call it where you're from)) goes into sleep mode, (as it was configured by default after xx...
