Using sound recorder with a USB microphone
tsuchenek
12:51 AM
I have tried to record audio with sounder recorder and a USB microphone. It doesn't work. Why? What else do I need to do.
windows 7 profesional
Did you set your USB microphone as the default recording device?
If you didn't, that maybe the reason.
Go to:Control Panel\All Control Panel Items
Then Sounds and click on the Recording tab. All your audio input devices must be listed there.
Right click on the preferred one and select the device as default and try the Sound Recorder again.
Take Care
Windows 7 Ultimate Service Pack 1Intel(R) Core(TM)2 Duo CPU T6400 @ 2.00GHz3GBNVIDIA GeForce G 103M
Compaq Presario
3GB
1366 x 768 @ 60Hz - Aspect Ratio 16:9
