Windows 7: [Realtek][Win7] "Scratchy" Sound Problem
10 Sep 2009   #11
kreesdqban
Hopefully MORE Win7 drivers start coming out soon... I have a new HP laptop which I decided to upgrade from Vista and am still having some issues with drivers and software...
10 Sep 2009   #12
Thompson9100
Well, I'm having a read headache now! I started off with the sound being fine, but then I tried running TOCA Race Driver 3 through Steam, and now I get this scratchy effect. What's even more puzzling, is I also have a separate Plantronics USB Headset which doesn't utilise the Realtek soundcard, and hey ho, they are also scratchy! I'm getting a bit lost now as to what it can be.
I didn't notice this problem until the last few days, and as I seem to have it on both sound devices, I'm thinking this is likely to be a Windows 7 or DirectX problem.
11 Sep 2009   #13
rangerevo8
Windows 10 x64
@DjDead
i really never install it..
but i dont think that will solve my problem..
quite happy when heard that your problem still persists.. (at least i'm not alone..)
i did tried many solutions and still no one can fix this problem completely (some did happen in lesser scale though..)
Just to share with you, from all driver i tested.. Reatek Driver R2.22 had the least chance of the "scratchy" sound..however its DirectX 10 (Vista driver)..
@Thompson9100
i strongly agreed with you that this is a Windows 7 (DirectX 11) problem..since my Vista (DirectX 10) in this same machine doesnt have this problem at all..
31 Oct 2009   #14
pcdoc24x7
It's the driver. I had a similar problem and tried many different things without success until last night when I was able to download the latest Realtek HD Audio Driver 2.35 for Vista/Windows 7....The problem was solved. Here is the link:
Realtek
08 Nov 2009   #15
vaddhu
windows 7
I solved the problem!!!!
Just use realtek hd audio drivers version 2.22
12 Dec 2009   #16
boaterich
Windows 7 home premium 32 bit
When I loaded W7 on my laptop the sound was scratchy, but it had picked up the Microsoft drivers I installed the Realtek 2.37 drivers, they were marked Vista and W7 and the sound was worse. I rolled back to the MS drivers and it was much better but I noticed that the internal mike was inoperative. Deleted the drivers, re-booted and the MS drivers installed again. The sound is pretty bad.
Are the drivers listed above, 2.22 and 2.35 still working OK? I don't have much hair left and the balance is in danger of falling out :-(
24 Aug 2016   #17
galleherjazz
New Jersey
I know this forum is quite old, but I have exactly the problem discussed in this thread. I would like to ask that if I were to install realtek hd audio drivers version 2.22, if I manually install it, will it override the later realtek on my PC? If it doesn't fix the problem, I presume I can put the realtek driver I have now back?
Anyone else have any major breakthroughs with this issue? In addition to the scratchy sound, simultaneous with the sound issue, my wireless mouse cursor starts acting erratically. They are definitely related, since both seem to go weird at the same time. If I rebott, both issues disappear until about an hour or two, and the issues recur.
This problem is really a nuisance and any help would be greatly appreciated!
Realtek HD Audio Problem: Headphones appear as "Speakers"
Dear all, my speakers do work. When i plug in my headphone at front the speakers get replaced, means I head everything through the headphone. Headphones themselves aint shown under "Sound": It appears that both, speakers and headphones are used as one source for audio-out. However, I...
No "Windows Start" sound in Win7?
Just noticed that Win7 has no sound option for "Windows Start." Is there a way to get this sound option back :rolleyes:
I Got Sound Card Problem "RealTek"
suddenly i lost the sound from the pc , i dont know wht happen , all wht i can notice tht the sound driver is installed ok but there is no sound , i will put a pic to describe wht happen http://i49.tinypic.com/34nji0w.jpg plz help me fast
Realtek HD Sound Card "invisible"
Hi there System: HP Pavillion a6030.za Desktop CPU: AMD Dual Core 3600+ 1.9ghz GFX: nVidia 8500gt OS: Windows 7 Ultimate x64 Service Pack 1 It has an onboard Realtek HD Audio Sound Card, not sure exactly what model as tireless searching on the internet has turned up nothing.
Realtek 5.1 Surround "Device In Use" problem (only stereo works)
Hi all, I've searched through the various threads on this issue, and aside from the complaining and finger-pointing, it appears 'Enhancements>Environment/Speaker Fill' seems to be the only option, which merely gives the illusion of true 5.1 surround sound. I've just today downloaded and...
Laptop speakers emit a "pop" sound after "Starting Windows"
For a couple weeks now, My laptop has been making a "pop" sound everytime on start up after the windows logo comes together it makes a faint pop sound then continues to the login screen. Everytime I muted or unmuted the speakers it would make the sound too. I changed my driver the the Windows...
