[Realtek][Win7] "Scratchy" Sound Problem
DjDead
6:04 PM
Problem Solved [Realtek][Win7] "Scratchy" Sound Problem
Hello
Ive been browsing this forum to see if I could find any solution to my problem but I havent been able to track down any. So I decided to go ahead and ask you guys ;)
First a little info about my specs:
Motherboard: Gigabyte GA-EX58-UD3R
Soundcard: Onboard Realtek
OS: Windows 7
Driver info:
Driver Publisher: Realtek Semiconductor Corp.
Driver Date: 06.07.2009
Driver version: 6.0.1.5888
Digitally Signed by: Microsoft Windows Hardware Compatibility Publishe
My problem is that I get this "Scratchy" sound when I play any sound, doesnt matter if it is a game or music or video. The sound is like from an old LP with a scratch in it. It comes at random intervals, its not there all the time. Barely noticable when I play metal music but when I play more "calm" music it becomes very noticable.
I have removed the drivers completely and reinstalled. I have tried the older version drivers also to no help. When I first installed Windows 7 it was all fine but after some driver update it started. Tried to install the initial drivers also but didnt help.
So what to do? Im pretty lost and Im getting very frustrated at this, I dont want to reinstall windows at the moment but it seems that might be the one and only solution unless one of you knows whats wrong.
Thanx in advance!
I am having a similar (actually worse) problem with the onboard realtek sound card on my Aspire T180 using Windows 7 RTM 64 bit. The Acer sit is useless, I downloaded the Vista/Win 7 Driver from Realtek site and at least I could get some sound sometimes, but so far not working only intermittently. I have a cheap (about GBP5) USB external sound card (small as a thumb drive) and it works fine. Hopefully Realtek will get its act together and get some proper Win 7 Drivers out soon.
Win 7 RTM 64bit
Win 7 RTM 64bit
Hmm, I just read something I must have missed in the Realtek thread.
I turned off the Gigabyte Energy Saver application and it has worked perfect since then. Just waiting for that annoying skipscratch sound to appear thou.
So far it seems to be the solution to my problem, will post here if it didnt help. Going to try to play some video files +++ to make 100% sure.
Edit: Seems my problem is no longer a problem. Fixxed in other words.. Thanks to the one posting this in the Realtek driver sticky thread!
If you have GTA 4 installed .. try uninstall it . :) Worked for me .
windows 7
windows 7
Thanx in advance!
Well, there are thousands out there suffering from realtek driver issues, me included. My advice: quit banging your head against the wall.
It's up to realtek to deliver a working driver and since the official release of W7 isn't until oct 22 being patient is best :(
vista x64/ win 7 x64phenom 9950 BE8 gbnvidia gts 250
me and myself
phenom 9950 BE
ASUS M2A-VM HDMI
8 gb
nvidia gts 250
realtek HD onboard
dual hd 19" tft
2 x 500 gb WDC
1 x 500 gb Seagate
1 x 1000 gb Seagate
1 80 gb raptor
1 usb 160 gb
standard issue
logitech g11
usb wireless MS laser 6000
18 mb (according to my provider :)
DjDead
I have the exactly same problem as you..
May i know what is Gigabyte Energy Saver application and how to turn it off? Is that inside my mobo BIOS?
Btw, I'm using Gigabyte G31M-S2L motherboard.
EDIT
Windows 10 x64Intel Core i7 3770Corsair Vengeance LP 16GB (4x4GB)ASUS ROG Strix GeForce GTX 1070
Windows 10 x64
Intel Core i7 3770
Gigabyte GA-Z77X-D3H
Samsung SyncMaster 2243
Samsung 850 EVO 250GB
Western Digital 3TB WD30EZRX
Western Digital 2TB WD20EARX
Seagate 1TB Barracuda 7200.12
Corsair Enthusiast Series TX850M
Cooler Master CM 690 II Advance USB 3.0
Cooler Master Hyper 212 EVO
8Mbps
Avast Free Antivirus
My dad had this problem on his computer. Turns out he had Dolby 5.1 enabled when he only had 2 speakers. This was causing the 2 speakers to be used as front right and left speakers (meaning they were acting as surround speakers) making them sound scratchy.
Might not be your problem, but if it was, its an easy fix....
Windows 7 Ultimate x64Intel P7350 Centrino 2 2.0 GHz4 GBIntel
HP Pavilion dv4t-1400
Intel 4 Series Chipset
Intel
IDT HD
14.1" HP BrightView
1280 x 800
250 GB WD Int. & 250 GB Toshiba Ext.
Belkin Laptop Cooler
Microsoft IntelliMouse Explorer 4.0
Same. I have a Logitech Headset and Rock Live sounds like crap.
I had realtek installed but it didn't seem to help
Win7Intel E8300 @ 2.832 GigsnVidia 9800GT
Win7
Intel E8300 @ 2.83
nVidia
2 Gigs
nVidia 9800GT
Acer V173
500GB HD
No..it is not caused by setting i guess..
this problem only happen in Windows 7 though.. weird.. (i will say that it might be related between DirextX11 and sound..)
however, i tried almost all suggestion in the internet still no fixes..
Windows 10 x64
Intel Core i7 3770
8Mbps
@rangerevo8
It is an application that follows on the Gigabyte driver CD. If you never installed it, I doubt that can possibly be the problem :)
@everyone
But my problem still persists allthou in a lesser scale than before. So Im still trying to figure out what is causing this distortion.
It is not due to Dolby 5.1 or similar settings as Ive set it to default stereo with nothing fancy enabled.
Hopefully MORE Win7 drivers start coming out soon... I have a new HP laptop which I decided to upgrade from Vista and am still having some issues with drivers and software...
Intel
IDT HD
14.1" HP BrightView
1280 x 800
Well, I'm having a read headache now! I started off with the sound being fine, but then I tried running TOCA Race Driver 3 through Steam, and now I get this scratchy effect. What's even more puzzling, is I also have a separate Plantronics USB Headset which doesn't utilise the Realtek soundcard, and hey ho, they are also scratchy! I'm getting a bit lost now as to what it can be.
I didn't notice this problem until the last few days, and as I seem to have it on both sound devices, I'm thinking this is likely to be a Windows 7 or DirectX problem.
Windows 7AMD Athlon 64 X2 4000+ Brisbane4Gb - 4x1GB Corsair 800MhzSapphire ATI Raedon HD4870 1Gb
Self-Build
Gigabyte GA-MA770UD3 Rev 2
Onboard Realtek HD Audio (for now)
Samsung Syncmaster 19" 4:3
3 x Samsung, aprox 770 in total (all SATA, 7200 spin speed, min 8Mb cache)
Cooler Master 600watt
Cooler Master Elite
Air - 1x12cm, 2x 8cm,+ similar to Arctic Cooling Freezer 7
@DjDead
i really never install it.. :p
but i dont think that will solve my problem..
quite happy when heard that your problem still persists.. (at least i'm not alone..)
i did tried many solutions and still no one can fix this problem completely (some did happen in lesser scale though..)
Just to share with you, from all driver i tested.. Reatek Driver R2.22 had the least chance of the "scratchy" sound..however its DirectX 10 (Vista driver)..
@Thompson9100
i strongly agreed with you that this is a Windows 7 (DirectX 11) problem..since my Vista (DirectX 10) in this same machine doesnt have this problem at all..
Windows 10 x64
Intel Core i7 3770
8Mbps
It's the driver. I had a similar problem and tried many different things without success until last night when I was able to download the latest Realtek HD Audio Driver 2.35 for Vista/Windows 7....The problem was solved. Here is the link:
Realtek
I solved the problem!!!!
Just use realtek hd audio drivers version 2.22
windows 7
windows 7
When I loaded W7 on my laptop the sound was scratchy, but it had picked up the Microsoft drivers I installed the Realtek 2.37 drivers, they were marked Vista and W7 and the sound was worse. I rolled back to the MS drivers and it was much better but I noticed that the internal mike was inoperative. Deleted the drivers, re-booted and the MS drivers installed again. The sound is pretty bad.
Are the drivers listed above, 2.22 and 2.35 still working OK? I don't have much hair left and the balance is in danger of falling out :-(
Windows 7 home premium 32 bitPentium Dual Core T23702Gb
E System 1201
2Gb
Realtek High Definition
Philips LCD
I know this forum is quite old, but I have exactly the problem discussed in this thread. I would like to ask that if I were to install realtek hd audio drivers version 2.22, if I manually install it, will it override the later realtek on my PC? If it doesn't fix the problem, I presume I can put the realtek driver I have now back?
Anyone else have any major breakthroughs with this issue? In addition to the scratchy sound, simultaneous with the sound issue, my wireless mouse cursor starts acting erratically. They are definitely related, since both seem to go weird at the same time. If I rebott, both issues disappear until about an hour or two, and the issues recur.
This problem is really a nuisance and any help would be greatly appreciated!
New JerseyIntel(r) Core(TM) i7-4790K CPU @4.00GHz16.0 GBNVIDIA GeForce GTX 745
HP 850-055qe
New Jersey
850-055qe
16.0 GB
OS (C:) SanDisk SD7SB2Q-512G-100 SCSI Disk Device (500 GB)
DATADRIVE1 (E:) hp BD-RE20N SCSI (2 TB)
Avast Internet Security
Chrome (Also Firefox, IE)
