Windows 7: Audio driver dilemma (Stereo mix problem)
16 Nov 2011   #11
Roderunner
Win7 H.Prem. 32bit+SP1
Your driver date is 2 years old. Have you tried the latest version R2.66. Stereo Mix works on my PC.
16 Nov 2011   #12
frozenfever
Windows 7 Home Premium 64-bit
I know that Stereo Mix works if I upgrade the driver, but then I lose to ability to use bass boost in the Enhancements menu, which I don't want to happen.
16 Nov 2011   #13
Roderunner
I apologise for my silly last post. I have looked at 'Sound' properties on both my pc's with R2.66 on both and their completely different. As I dont have headphones, what happens when using yours with 'Equaliser' ticked in the properties menu?
17 Nov 2011   #14
frozenfever
My current driver doesn't have an equalizer in its enhancements.
Can't record audio from Stereo Mix
See the title. For a while now, I've been trying to record audio that output from my speakers, but have been unsuccessful. I have already activated Stereo Mix and am trying to record from it, but nothing comes out. Interestingly, the green bar in Sound Options next to Stereo Mix DOES fluctuate, I...
VIA Audio Stereo Mix doesn't work
Hello Guys! Please excuse my english :p For the last few days i've been trying to solve my problem, I'm trying to record Stereo Mix sound, but it just doesn't work, my motherboard is a Gigabyte GA-Z77X-UD3H. I have enabled it but when I go to settings of the Stereo Mix the volume is...
Realtek Audio Only Stereo
I have a Gigabyte GA-EP45T-UD3LR with realtek ALC888 audio and current driver of 6.0.1.6449. I can only get 2.1 through my optical out with the exception of dvd's or the test under sound / properties / supported formats and the test in media center. I think the problem is under playback devices...
No 5.1 option in Realtek HD Audio Mgr - only stereo
Hello and thank you, I have an Asus M4A89GTD Pro mobo, winch has on-board "Realtek ALC 892 8-Channel High Definition Audio CODEC". This is a brand new build. I'm using a TOSLINK optical cable to connect it to a Samsung HT-TX72 receiver, set up w/ 5.1. I've downloaded, installed and...
AMD ATI HDMI 5.1 AUDIO instead of STEREO
End result... It seems HDMI units be them a PC or BLURAY player etc... do a hand shake of sorts with the other end. So, No options accept stereo in my "AMD HDMI output" config using an HDMI cable from PC to 55" LCD TV and then an optical out from TV to 8 year old Kenwood reciever :((Hey tight in...
HP printer driver dilemma
I recently installed Windows 7 ultimate (W7) onto my PC. ( Just as an aside, I think that this is probably one of the best windows OS that I have worked with.) Anyway, I have two HP printers (office-jet 4215, and photo-smart 7550) that don't have drivers for windows 7. I wanted to connect both...
Hardware & Devices
